Old 05-06-2016, 05:36 PM   #1
bluedragoncamaro
Drives: Camaro
Question Auto transmission nitrous need help now.
I have a 2011 automatic v6 Camaro. I plan on purchasing the ZEX nitrous kit this weekend. Everything is figured out, exhaust, intake, headers, working with Trifecta right now, getting the purge kit, pressure gauge, but here is where im confused... It says the ZEX system engages at WOT, I get that, I understand how it works and how to program it. And I also see window switches, wich I understand and know how to program it (from reading manuals) I plan to buy the NOS dual stage window switch to use the second stage possibly to trigger exhaust cut outs. The automatic transmission, it says I shouldn't spray under 2500, but I launched between 1000rpm and 2500rpm so I assumed I would get the window switch to only activate after 2500 rpm, and I know the rev limiter will cut the fuel so I plan to add a little more rpms to the rev limiter as a buffer and set the window switch to below it slightly so it will stop spraying incase it hits rev and cuts fuel. THIS is the confusing part, im tuning my tranny as well to shift harder/quicker and I read its bad to spray through shifting and i heard it wasn't. But I stay at WOT through a shift (automatic duh) so as soon as that nitrous shuts off its instantly back on because the rpms drop for the next gear. So here are my questions/concerns.
During an automatic shift does it cut fuel OOORRR temporarily disable WOT voltage until its back in gear?
If it doesn't how would I stop spraying just before the shift and start spraying after it has shifted?
And last am I just over thinking things and need the window switch for low rpm safety and rev limiter safety and just pedal to the metal and let it spray away?
I would like the AUTOMATIC nitrous owners to chime in please, or people who know how to nitrous an automatic vehicle. This isn't a bs hopes and dreams thread, I'm seriously buying everything this weekend. Thank you!
bluedragoncamaro is offline   Reply With Quote
Old 05-06-2016, 05:39 PM   #2
bluedragoncamaro
Drives: Camaro
I mainly just surf this site, it's really helpful. I'm ordering parts today so I need to know what I need in addition to the nitrous kit.
Old 05-06-2016, 07:09 PM   #3
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
I and some others in here like etmx183 with auto spray through the shift. I actually have mine set to spray up to 7200rpm. The issue I found by having it cut off at the shift is I would get knock retard when it comes back on again. I know a lot of guys like the cost and simplicity of window switches, and I had one too, but spend a little more and be happier with the nos mini controller.
My car is nearly 90k miles and spraying most of it, and lots of testing. Even though you never know when a weak part will let go, these motors and trans are tough.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 05-06-2016, 08:54 PM   #4
bluedragoncamaro
Drives: Camaro
Do you have a link to that part? I ordered the NOS dual output window switch, I just spend $2200 on an entire system for my car.
Old 05-06-2016, 09:24 PM   #5
IneedAZ
IneedAZ's Avatar
https://www.holley.com/products/nitr...parts/15974NOS
Old 05-07-2016, 12:46 AM   #6
bandido
Drives: camaro v6 2013
I have an automatic as well and i think it diasbles WOT it can briefly feel when it happens
bandido is offline   Reply With Quote
Old 05-07-2016, 08:53 AM   #7
IneedAZ
IneedAZ's Avatar
It will turn off the nitrous when you lift your foot off the pedal. The beauty of the mini controller over the window switch you can control how much spray it initially sprays and brings in the rest over time. If I were to spray 100 on street tires off the line i wouldn't get very far(no traction), however the controller allows you to find the sweet spot.
Old 05-09-2016, 11:52 AM   #8
bluedragoncamaro
Drives: Camaro
Well I just ordered everything. I talked to ZEX and a few guys who have nitrous on their v6 a6 cars and I should be safe with a window switch and the trifecta tune. I might make a write up on instalking everything.
auto, nitrous, zex
