![]() Drives: 2010 Camaro 2SS/RS & 2006 Cobalt LT Join Date: Mar 2009
Service Stabilitrak? (Launch Control)
Hello all, I posted this awhile back;
Launch Control problems -------------------------------------------------------------------------------- Hey guys, I did a search and couldn't find my exact problem, but forgive me if I missed it. Anyways, I HAVE gotten launch control to work in my car before (when I first got it back in June), but am recently having problems using it. So, I hit that button twice, put it in competition mode while the car is not moving, put it in first gear, floor it and dump the clutch, correct? Well, when it works, the RPMs hover around 4-5k (?) I believe. But recently it will just red line, making it so the ass end kicks out when I launch it (yikes). Has anyone else had this problem, or has it been addressed? ------------------------------------------------------------------------- Well I am aware of the issue where you must FLOOR the gas instead of gently press it down...it still doesn't work! ...And now, whenever I start my car, I get a "Service Stabilitrak" message popping up in the center (between the speedometer and tachometer). Any suggestions? I hope this is covered under the warantee
![]() Drives: 2SS RS Yellow, Raptor, Vrod Join Date: Jul 2009
Figured it out yet? There is another post with a similar problem and am waiting to see how to fix it!
2SS RS Rally Yellow, LS3, M6, sunroof, extra on the fast!
Apparently if you start the car and hold the key instead of "tapping" it with electronic start it will give you the error message.
Evl Bee
I am having the same prob, I tried the launch control once and it has not worked since. I have not takin it in yet but as soon as I can I will let you know what theysay.
![]() Drives: 2010 2SS/RS Join Date: Nov 2009
So basically you guys are saying you only had the launch control to work once and that was it? Since then this message has been appearing? Also anyone out there have a vid of the new ss using launch control i would love to see it.
10 2SS: LM1, K&N drop in. SOLD
14 2SS: stock...ish |
#6 |
Drive fast take chances
I have tried launch control and have had it work and not work. Seems that most of the time it doesn't work. I talked to a GM rep and they said to stomp (floor the gas pedal)but again sometimes it works and sometimes it doesn't. I wish that it would work consistently like the owners manual says. Scares ya pretty good when you stomp on it and it goes to redline. YIKES.
Now I just feather the throttle around 3k with traction control off and let it rip. Seems to be more consistant. Does anyone have a better solution to get it to work everytime. |
#7 |
Evl Bee
I took mine to 2 different Chevy dealers
and neither were able to tell me anything, they had no clue... infact one even googled it in front of me cause he never heard of it! (Henderson Chevy in NV
#8 |
Evl Bee
Got a straight answer from the dealership, your tires have to perfectly straight and everything has to be perfect, got it to work again.
| Please EXPLAIN Stabilitrak/Traction Control, Launch Control! | drtwo | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 10 | 01-26-2018 10:47 AM |
| 2010 Camaro Launch Control = Transmission Failure | camaroguy | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 140 | 07-06-2013 12:27 AM |
| Camaro SS Launch Control | jdpickering | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 35 | 12-23-2009 10:29 AM |
| Launch control suggestions.... | AVman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 09-26-2009 02:03 PM |
| COMPETITIVE MODE AND LAUNCH CONTROL (V8) DIRECTIONS | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 80 | 05-02-2009 01:20 PM |
