![]() Drives: 2010 grey cammed ss Join Date: May 2016
What should I do next
Hey guys I'm looking to get some more power out my car but I feel like I hit the wall of doing all the cheap stuff exhaust headers intake cam gears and tuned got drag radials upgraded axles and trailing arms so now I'm stuck as to what I can do without breaking the bank. I'm getting married in the next few months and shouldn't be buying toys but oh well. I was thinking heads and maybe a 100 shot down the road possibly a e85 tune but I'm not that familiar with motor work so don't really know what my best bang for my buck is because everyone I talk to tell me to strap a supercharger on it and be done well I don't have a spare $8,000 or probably more right now lol, thanks in advance guys
blessed...2010 cyber grey SS Cammed, kooks headers, mbrp exhaust, vararam intake, 3.91 gears
458RWHP 433RWTQ ![]() |
BUMBL Z
Look into the lsa conversions, cheaper and can make solid power
Sent from my Nexus 6P using Tapatalk
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
Personally, I'd recommend firming up the suspension if you haven't already. There is a lot to be gained from suring things up. It will even help you put the power you already have down better.
The heads aren't a bad idea but you are going to spend BIG money to get gains that aren't justifying the expense IMO.... That same $2,000 or so could maybe be spent better elsewhere? What do you have in mind for the car long term? All the best, Jared Royce 801.545.4215 |
#4 | |
BUMBL Z
Have you upgraded your clutch yet? I'd imagine your nearing the limits of a stock clutch, could be a good idea to beef up supporting mods
#6 |
thanks! wish i would of went this route from the start but from what i read and correct me if im wrong by the time they add cai fuel pump and retune there back in that $7,000 or more range and ill most likely need a cam change. its not that im trying to cheap out or cut corners if it was up to me id throw 20 grand in it if i could
#7 |
old school chevy rodder
Doing heads would only gain you what is to be given by your cam and the numbers you post are low for a cammed car therefore I believe a better cam may serve you better.( unless that dyno sucks).
I had a stock 376 cube ls3 with CAI , headers/ HFCs, TSP 235/239 cam for 491 hp and 448 trq, tuned on a dyno right, anyway I have electric power steering and dual mode.... but this is from a Mustang stingy dyno.... I would wonder what specs are on the cam. Some of us deliberately undercam to be easy on the valve train until upgraded further or heads/intake etc are added. Sometimes a mild cam can be very FI friendly also compared to others also, and with wider LSA easier to drive and not post big numbers . Dyno numbers are subjective and need to be compared to other dynos read outs for the same exact everything to be considered. There are other modifications, drive shaft safety loop, MGW shifter, shift light, interior and exterior things that can be fun.... Ever look at American Car Craft...LOL Basically you need to know what your looking for it too do, and unless your daddy warbucks it takes time and that's one of the fun things about hot rodding. Heck I used to have fleet..LOL
#8 | |
458RWHP 433RWTQ ![]() Last edited by Minimav77; 05-10-2016 at 09:25 PM. |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
suspension it the best thing you can do to this car. if you're ever going to break 500hp a new rear end and a clutch. clutch wouldnt be bad now. Im going to let mine go till its gone at 477hp 465ftlbs
#10 |
Drives: 2010 2SS/RS Join Date: Jun 2009
If you already have the fuel upgrades I'd do e85 m
#11 |
![]() ![]() ![]() ![]() Drives: 2010 2SS/RS L99 IBM silver stipes Join Date: Dec 2015
Not to that power level yet. But, I would start upgrading the suspension. It makes a lot of difference.
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough.... |
#12 |
![]() ![]() Drives: 2010 Camaro SS Victory Red Join Date: Apr 2015
Just enjoy your car
Speed Engineering Headers w/ Texas Speed HFC's ~ Flowmaster 2 1/2" cat back w/Flowmaster Super 10's ~ Cold Air Inductions Intake w/ Scoop and WW relocate ~ VMAX CNC Spiral PTB ~ Cross Drilled and Slotted Rotors w/Hawk pads ~ ZL1 Spoiler ~ SCTX4 RDP Tuned
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 13' 1LE Join Date: Apr 2012
Nitrous is the way to go for best bang for the buck. Go with a 150 jet. But youll need a new clutch very soon..
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
#14 | |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
| Tags |
| detroit, e85, heads, metro, nitrous |
