Old 05-11-2016, 06:33 PM   #1
allshotout
allshotout's Avatar
Drives: 2014 SS Camaro
Question ECS Kit on 14-15 Camaro Question
Just curious if anyone knows of folks that have installed ECS Kit on 14-15 SS Camaro, and when they did what modifications needed to be made? If any? Doing install on 14 at the moment and have run into fitment issues when it comes to radiator brackets being these were changed in 14. Couple other little issues, but those things happen (I get it). Mainly wondering about having to mod radiator brackets to clear heat shield when hood is closed.
allshotout is offline   Reply With Quote
Old 05-11-2016, 09:09 PM   #2
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Sorry, can't help you but I'm deciding on the ecs or agp kit and looking to install myself. So I'm guessing they don't have updated install instructions for the 14-15 camaro?
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 05-11-2016, 10:13 PM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Have you contacted ECS?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-12-2016, 11:13 AM   #4
allshotout
allshotout's Avatar
Contacted them? That's an understatement. Finally, got to machine/fab shop that makes kit brackets. Took a while to finally get to him, but he has been extremely helpful and been back and forth on the phone with the shop working through things for last week. He too was surprised to learn of the change in 14-15.
Old 05-12-2016, 11:16 AM   #5
Silver14
Drives: 2014 SIM 2SS
Thanks for posting this, and please keep the thread updated with the resolution. I have a 2014 and am trying to decide between the ECS kit and AGP.
Silver14 is offline   Reply With Quote
Old 05-17-2016, 06:30 PM   #6
xXSicSicSicXx
Drives: 14 1LE
any update? you're the only person i've heard of having problems..
xXSicSicSicXx is offline   Reply With Quote
Old 05-17-2016, 07:29 PM   #7
todd69gs
todd69gs's Avatar
Drives: 2014 Crystal Red 1LE 2SS
ECS needs to step up and make the necessary changes to their kit for the 14-15 cars. Crazy to think you spend 6k for a bolt on kit and have to do custom work on top of it.
todd69gs is offline   Reply With Quote
Old 05-17-2016, 07:37 PM   #8
760bowtie
760bowtie's Avatar
+1
Old 05-17-2016, 09:07 PM   #9
xXSicSicSicXx
Drives: 14 1LE
hmm inbox is "full"
Old 05-17-2016, 09:41 PM   #10
bowtienick
bowtienick's Avatar
Drives: 2010 ss m6
radiator bracketing changed. You can't expect an aftermarket vendor to keep pace with GM changes, lol
bowtienick is offline   Reply With Quote
Old 05-17-2016, 11:06 PM   #11
todd69gs
todd69gs's Avatar
Why not? They built it for the 10-13 right? So if a small change is needed for the 14-15 models the vendor should be on top of that. Guaranteed sales will suffer if people have to buy the kit then customize it to fit their car.
Old 05-18-2016, 06:28 PM   #12
xXSicSicSicXx
Drives: 14 1LE
apparently they're sending him new gm brackets from what jdp told me.. other than that nobody seems to have this problem..
Old 05-18-2016, 06:51 PM   #13
todd69gs
todd69gs's Avatar
Thats good to hear.
So no one else w a 14-15 has run into this issue?
Old 05-18-2016, 06:59 PM   #14
allshotout
allshotout's Avatar
That's news to me?? My 14 had the super-duper performance radiator brackets. Actually made our own radiator brackets.
