Happy
eee
![]() Drives: Camaro Z/28 Join Date: Apr 2016
Just checked into Lingenfelter upper end stuff myself. Depends on budget!
http://www.lingenfelter.com/category/C485.html |
#3 | |
![]() ![]() Drives: 14 Z/28 0# Join Date: May 2013
"PTM11" Search & Destroy
Drives: 2010 Camaro SS Join Date: Dec 2015
Here is a dyno graph with 2 of our cams in a LS7 C6. The lower power cam is the Nicky6 cam and the higher is our SS3 camshaft. If you have any questions on anything feel free to send me a message or call me.
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
Was there not a warranty with that 650 package?
Looking forward to your rebuild.
Keeper of the 5th Gen Z/28 Registry.
Registry Facebook. Follow: @5th_gen_z28_registry I track wrecked Z/28s Total lost -41 |
#6 |
#7 |
![]() Drives: 14 1le Join Date: May 2012
I made over 600rwhp with the prc 285 heads. This was on a resleeved ls2. 454 cubes. A 247/263 113+3 .688 lift cam. It ran strong.
06 gto Maggie 489 rwhp sold
05 gto ERL/HKE 454 609rwhp na sold 06 Z06 500 rwhp sold 10 2ss ERL 427 530 rwhp sold 14 1ss 1le |
#8 | |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
Detonation, even not heard, puts way more stress and cylinder pressure at the wrong time and place that normal compression does. The LS7 gets a bad wrap, but, it's usually tuning issues that kill them. |
#9 |
![]() Drives: 15 Z28, 17 GT350R Join Date: Nov 2015
#10 |
And what would that have gotten me? I already knew Hennessey was suspect.... I liked the car, I liked the color of the car... what would a google search done for me? Im not complaining about having to fix my motor.. most LS7's will have to go through this at some point.
#11 | |
![]() Drives: 2015 Chevrolet Camaro Z/28 Join Date: Mar 2016
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 416 Join Date: Feb 2013
i have 4 of those blocks all but one has number 7 sleeve cracked and the alum behind is also cracked
#13 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
#14 |
Well, I bit the bullet... Doing a rebuild and upgrade.
LS7 Block Sleeved with Darton Sleeves Trick Flow Gen X 260 Heads JHR Custom Grind Cam Wiseco Drop in LS7 Pistons Already have the MSD Atomic intake Looking to get about 615 HP 570 TQ to the wheels. Will update when the project is done. |
