Old 05-12-2016, 05:03 PM   #1
Orange 2010 Camaro
Orange 2010 Camaro's Avatar
Drives: 2010 2SS/RS Camaro
WINDOW IN DOOR DOES NOT DROP DOWN WHEN DOOR HANDLE IS PULLED?
I have a 2010 SS & a couple of days ago I noticed that the window in the passenger side door will no longer drop down about 1/4 inch to clear the upper seal when you pull he handle to open the door.
The car is out of warranty, so I am on my own on this one. ( I WILL NOT PAY THEM $100.00 AN HOUR TO FIX IT!). Has anyone else had this problem & what was done to fix it?
Thanks in advance for all your help.
All The Best
Orange 2010 Camaro
Orange 2010 Camaro is offline   Reply With Quote
Old 05-12-2016, 05:22 PM   #2
badcompany
Drives: 2010 Summit White 2SS
Have you tried the window reset? If not the process of how to do it is in the owners manual. I've had to do it once already!
badcompany is offline   Reply With Quote
Old 05-12-2016, 05:25 PM   #3
Ledzepx
Ledzepx's Avatar
Drives: 2010 2SS Camaro 6sp.
I beleive you can do this. i had to reset my window once before.
Ledzepx is offline   Reply With Quote
Old 05-13-2016, 12:19 AM   #4
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
not trying to thread jack, but my window doesn't fully auto-up anymore, it'll get around a half inch from the top and then roll down half way. driver side only, window reset didn't help
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 05-13-2016, 07:27 AM   #5
MCSarge
USMC 1980-1990
MCSarge's Avatar
Drives: 2010 Camaro 2SS/RS
You both need to reset your windows. The procedure is easy and in your owners manual.
USMC 1980-1990
My other toys are Harleys
MCSarge is offline   Reply With Quote
Old 05-13-2016, 08:03 AM   #6
hesster
hesster's Avatar
Drives: '10 T/A Conv, '10 2SS, '77 SE T/A
This works -
1-A. Open the car door which needs to have the window adjusted. Turn the ignition to the run mode. Do one door at a time !!!
1-B. In the door jam, release the harness from the door (with a medium screwdriver, pull up the release tab, pull off w/ the palm of your hand, and pull the harness off the door for a minimum of 60 seconds (this is very important as the memory will be lost).
1-C. Reconnect the door harness and lock the tab back down. Close your car door.
1-D. The DIC will ask you to lower your door glass.
1-E KEEP YOUR FINGER ON THE BUTTON FOR 4 TO 5 SECONDS ONCE THE GLASS IS DOWN. ROTATE YOUR FINGER TO THE UP POSITION AND HOLD FOR 4 SECONDS ONCE WINDOW IS AT THE TOP.
OTHER FUNCTIONS MAY APPEAR IN YOUR DIC BEFORE YOU ARE ASKED TO PROGRAM THE WINDOWS. This is normal
Window is now reprogrammed, Repeat to the other door glass.
However, sometimes the door glass regulator does not always relearn on the first attempt. If when you open the door and the door glass does not drop down to the open door position, your window regulator did not relearn or re-normalize...in which case, you are going to need to drop the glass back down, unplug the harness and try again. Yes, it can be picky sometimes and not want to work on the first time.
hesster is online now   Reply With Quote
Old 05-13-2016, 12:04 PM   #7
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Originally Posted by hesster View Post
This works -
Tried this like 4 times on my driver door alone, thing doesn't wanna take
Old 05-13-2016, 01:32 PM   #8
MCSarge
USMC 1980-1990
MCSarge's Avatar
On my 2010, it said to close all doors. Put the key in the run position (do not start car), push the button and roll the window down, then put it up and hold the button for 4-5 seconds. Do the same with the passenger window. I never had to disconnect any wiring.
Worked the first time I tried it. Good luck
USMC 1980-1990
Old 05-15-2016, 06:27 PM   #9
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
May sound stupid but I had a similar problem, turns out the battery was weak and near the end it's life. Took very long cranks, etc. changed the battery and worked fine after the reset. Do you have the original battery still.
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
