Tri-County Camaro SWFL
Ceramic Coated Intake
I have a Halltech Yellow jacket CAI, I read IAT off of an Aeroforce Interceptor scan gauge.
I dropped my intake tube and heat shielding off at a local powder coater that also does ceramic coating. I've been doing some research and the only people, that I've found, to have ceramic coated their cai intake piping is on an RX8 forum. Seems to be about the same results I have pre coating. I will get the intake and heat shield back in "about a week". IATs (in my application via Aeroforce Interceptor) is about 8/9 degrees above what the car is reading for outside temp. While sitting for 30 seconds at a red light the IAT skyrockets, it will peak as high as 150 degrees depending on how long I sit at that given light for and take a min or two to cool back to 8/9 degrees above outside temp. I know CAI inductions ceramic coats their intakes in house and sells them ceramic coated. Gave me the idea of having my intake ceramic coated. What do you guys think? Do you see a benefit in ceramic coating an intake to prevent heat soaking? Thanks for reading
Last edited by CamaroDreams76; 05-13-2016 at 02:34 AM. Reason: spell check and changed some wording |
#2 | |
Banned
Can't hurt. I have too much heat for the CAI inc to overcome right now so I'm fixing to heat wrap it like exhaust as well |
I would ceramic coat my headers too but it took 10 hours to install them. I'm really not feeling it, I know that would be the biggest benefit to my car since the headers are non coated.
![]() ![]() Drives: 2012 SS/RS MN6 Join Date: Mar 2016
Did it on jackstands. Was a PITA. Had to disconnect the starter on one side (I improvised) and had to disconnect the steering shaft (improvised again and just made it fit). Changing the plugs took a long time on its own. The design of the header was the real problem.
#6 | |
#7 |
Holley Blackheart shorties (future TT build, wanted the car louder). Can't even get a sparkplug socket on the plugs in the back half of the motor without backing the header bolts almost completely out.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
The guy who sold me this Airaid intake a while ago said it ran high IATs. I did this to my intake air box and wrapped the intake and it now runs at ambient.
#9 | |
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly ![]() |
#10 |
100% Chevy & Harley Man
Drives: 2010 2SS: Blown LSX 376-B15 Join Date: Feb 2009
When I was in the process of getting some ARH headers installed, I asked my builder about getting them ceramic coated. While I can't remember the exact response, it was something like that it wasn't worth it because the coating burns off within a year or 2.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
#11 | |
I will certainly post my findings. The RX8 guy said the intake after being coated only rose 7 degrees at lights and keep around the same IAT while driving. Also the intake would instantly drop tempature, not slpwly go down after a few min of driving. The intake wouldn't heat soak anymore. That's the results I'm shooting for.
#12 |
Huh...... I don't see any forums here about people's coating coming off on their headers. Good thing to keep in mind for sure. It being my intake, it's an easy thing to keep an eye on.
#13 | |
![]() ![]() The Coating on the just over a yr old CAI Intake is done well and still looks brand new. imho If applied right don't think you will have any problems with durability. Best wishes look forward to seeing final product and hearing results
#14 | |
![]() ![]() ![]() ![]() ![]() Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
