![]() Drives: 2015 Camaro 2SS 1LE Join Date: Feb 2015
What 60ft times should I be able to cut?
Hi guys, I'm on 20" Mickey Thomson drag radials. What psi should I run? What rpm's should I launch at? I can't get the car to launch correctly at the strip!!! My best pass with a 2.04 60' is an 12.34 @ 117.2. I really want to run high 11's N/A and low 11's on spray. What do you guys think my approach should be? Thanks!
AGP Twin turbo kit, base 54/57 Borg Warner turbos, TSP stage 4 N/A cam, AGP twin 430lph e85 pump fuel system w/ flex fuel sensor, 1000cc FIC injectors, Grimm speed manual boost controller. (830 rwhp 778 rwtq @ 15.5 psi)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 camaro ss Join Date: Jun 2010
Seat time. Learn how to slip the clutch better. That's what I was running in my but I was on street tires. Make sure you do a real smokey burnout on those mt's. I would probably start at 20 psi and go from there
![]() Drives: 2010 Camaro RS/2SS Join Date: Sep 2015
15psi on ET streets, exhaust + tune, made 392/393 and ran 12.08 with 1.6 60'. Manual car.
2010 Camaro 2SS/RS M6
12.08 @ 115 - 9/2015 (392hp/393tq) NA w/ Exhaust + Tune 11/2015 (464hp/439tq) ^ + BTR Stage 4 w/ Halltech CAI Engine: BTR Stage 4 Cam; BTR Dual Spring Kit; C7R Chain; LS2 Tensioner; High Volume Oil Pump Drivetrain: ACT T2S-G05 x2 Disc XT Street Kit Exhaust: Kook's 1 7/8" Headers w/ Off-road pipes;Kook's 3" cat-back; QTP 3" cut-outs Suspension: BMR 1.4" Front & 1.5" Rear Springs; Blackdog Solid Mounts w/ Poly Bushings |
What rpm did you launch at??? That's awesome for those mods!
5000-5500rpms. Stock rear end (3.45s) and stock drivetrain components. Many passes and no breaks. E-brake + clutch slip.
#6 |
Yes, this is the recipe (bold) once you fine tune technique.
#7 |
I've actually never heard of that lol. Ebrake??? Pull the ebrake while loading the clutch?????
#8 | |
There will be no drivetrain shock and you'll already have suspension and everything preloaded. I hurt people's feelings lb/lb power/power lol.
#9 |
![]() ![]() Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
By holding the e-brake and slipping the clutch you load the drive train and suspension; takes a lot of the inital shock off the drive train.
#10 | |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
#11 | |
#12 | |
Most passes I made back to back was two and pedal gets a little squishy so I wouldn't recommend hot lapping.... I got 80k out of my clutch and beat the hell out of it at the track. When I put my twin disc on the discs were definitely needing changed. 480rwhp on my ET streets was not friendly on the stock clutch. If you got radials or street tires it's perfectly fine. Higher levels you're gonna have to let the stock clutch cool between passes, especially with slicks on.
#13 |
I tried this several times at the track and didn't have any luck doing this. Tires would just spin. This was on street tires. Maybe it would've worked great with some sticky tires. I'll never know now
#14 |
Lol... You took your LS3 to a strip and tried to make a good pass on street tires? You will never hook on any method doing that on street tires. @ 480rwhp I couldn't even hook in 2nd unless I was less than 3500rpms going down the road. These cars make way too much torque. Don't waste your time running your car at a strip unless on radials or slicks. Waste of time/money.
