Old 05-13-2016, 07:35 PM   #1
total package
Drives: 2014 GMC All Terrain, 2015 Z/28
Spring Spacers
Am I the only one that still has their front spring spacers in?? Just under 1500 miles and I discovered they had not been removed!! How do you remove these??? I feel like a frigging idiot!!!
total package is offline   Reply With Quote
Old 05-13-2016, 07:57 PM   #2
phillyflyer
phillyflyer's Avatar
Drives: 2015 Z28
Your dealer is a dope!
It is part of their delivery/inspection process; you would not have know unless you knew to look for it...
Go For Wand - RIP October 27, 1990
phillyflyer is offline   Reply With Quote
Old 05-13-2016, 08:07 PM   #3
total package
Not happy......
Old 05-13-2016, 08:31 PM   #4
total package
Could anything be damaged? Did driving it like this effect chamber, alignment, tire wear etc?? I assume all of these things need to be looked at?? Thanks for any insight.
Old 05-13-2016, 08:32 PM   #5
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
If you just drove it around town, which I assume you did to break it in first before going to a track or driving it hard, you should be fine. Just jack up the front end and remove the spacers.
Mods:
Old 05-13-2016, 08:36 PM   #6
total package
Yes, I did take it easy. Are any special tools required or do they just slide out once tension is removed? Thanks for your help.
Old 05-13-2016, 09:34 PM   #7
4 FN 27
Drives: 2015 Z28
I took mine out by hand. Just twisted then right out. Give a try. Might be a little easier with it up on a jack.
4 FN 27 is offline   Reply With Quote
Old 05-13-2016, 10:34 PM   #8
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
Jack the car up and they will come right out.
Keeper of the 5th Gen Z/28 Registry.
Registry Facebook.
Follow: @5th_gen_z28_registry
I track wrecked Z/28s Total lost -41
Zslash28 is offline   Reply With Quote
Old 05-14-2016, 06:55 AM   #9
exboss
Drives: 2015 Z/28
does anyone have a picture of them being in place? I have no idea if mine are in place. I took it to the track once already and everything felt pretty good.
exboss is offline   Reply With Quote
Old 05-14-2016, 07:01 AM   #10
nvydvr
nvydvr's Avatar
Drives: 2015 Red Rock ZL1
They're yellow, if you look into the front well you'll see if they're there. But, when the dealer removed them they should have put them in the trunk or given them to you so you could put them in if you ever transport your car.
Alex
2015 Red Rock ZL1
Panama City Beach, FL
nvydvr is offline   Reply With Quote
Old 05-14-2016, 07:05 AM   #11
Zslash28
Jumanji
Zslash28's Avatar
From Google. They are bright yellow. Very hard to miss, that is unless you are they guy doing the PDI.
https://www.google.com/search?q=2014...KHCzLKXpCYM%3A
And here is what they look like removed.
https://www.google.com/search?q=2014...eAGgSQkDpZM%3A
Registry Facebook.
Old 05-14-2016, 07:07 AM   #12
Zslash28
Jumanji
Zslash28's Avatar
Precisely. Though, they fit better in the jockey box, which if I recall is where the PDI says to put them.
Registry Facebook.
Old 05-14-2016, 07:12 AM   #13
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Had to buy them from a dealer so I could load onto the trailer
Once you jack up the corner they slide right out
Crash76 is offline   Reply With Quote
Old 05-14-2016, 07:52 AM   #14
total package
I got them out. Come out very easily once car is jacked up. Thanks gang for the advice.
