Old 05-14-2016, 10:43 PM   #1
rcjohn9085
Drives: 2500hd
2011 Camaro ss mt misfire 303
I have a computer and came back with misfire in cylinder 3. I erased it and double checked. Autozone did it as well and got same issue.
So my problem, the car check engine light comes on randomly, as well as service stability track. The car itself always seemed to start hard, where it doesn't want to crank over but than it does, it doesn't take much longer than starting any other car though.
Info about car:
Got used from dealer with 10k miles on it last summer. Put 10k more on it. Had to replace battery after a few months. Also, the rear center brake light is out, and I have to replace that. When we first got it, tpms was a issue for a few days, but than fixed itself. Parking assist was also a issue, it didn't work, but after I disconnect battery randomly one day, it fixed itself. However it was like this for months.
I added a stereo head unit, reverse camera, kn intake with the ram air.
Other than that, nothing else.
So what I did to fix current issue:
Replaced all plugs with ngk, and still have bad code.
I tried changing plug wire from 1 and 3, but 3 still shows misfire
So what next?
I bought extended warranty from dealer, if I use them, I won't get my $1800 back. So I'm trying to check as many things as possible before I bring it in.
rcjohn9085 is offline   Reply With Quote
Old 05-15-2016, 12:07 AM   #2
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
Swap the coils around to see if the misfire follows. If it doesn't then either you have an injector issue or a compression problem. Get rid of the NGK plugs for a delco plug.
JerTM is offline   Reply With Quote
Old 05-18-2016, 01:04 PM   #3
rcjohn9085
Drives: 2500hd
Thanks for reply
I am going to try coils today, if still a issue in going to get a compression tester.
Do I need to remove all the plugs to test just the one cyclinder?
Or just cyclinder 3?
And can I just get away with removing the fuel pump fuse and ignition module(or whatever is distributing the spark to the plugs)
Old 05-18-2016, 02:29 PM   #4
rcjohn9085
Drives: 2500hd
Swapped coils, still throwing cyclinder 3
Doing compression soon
Old 05-18-2016, 04:10 PM   #5
rcjohn9085
Drives: 2500hd
Compression was about 190 for all 8
Sooooo yeah.
Old 05-18-2016, 04:15 PM   #6
10 Silver Bullet
10 Silver Bullet's Avatar
Drives: 2010 Silver SS2
that's weird I would stay on the dealer about fixing it if you still have warranty
10 Silver Bullet is offline   Reply With Quote
Old 05-18-2016, 06:33 PM   #7
rcjohn9085
Drives: 2500hd
Spark plug from that cylinder was dark(these are brand new and the rest are clean)
Not sure if oil or if burnt. It didn't seem real whipe able, so maybe fried rather than oil?
Ignition electrical or fuel injector issue win this cylinder?
Old 05-18-2016, 10:04 PM   #8
rcjohn9085
Drives: 2500hd
Switched fuel injectors, didn't fix it
So thinking either electrical with the injectors or spark plugs(prior to coil), which I could fix if I knew where to begin
Unless it's a piston or valve issue, which I am not capable of fixing
Old 05-19-2016, 01:01 PM   #9
Night trained
Night trained's Avatar
Drives: 2015 camaro 2ss 1LE
Do a cylinder leak down test. If ok pull that odd bank v/c and check valve spring.
Night trained is offline   Reply With Quote
Old 05-19-2016, 09:33 PM   #10
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
I've got bad plugs out of the box before....might try a swap
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 05-19-2016, 09:37 PM   #11
JerTM
JerTM's Avatar
Ok. You've eliminated a coil , plug, wire, injector, and compression. A very dark plug could be oil or excess fuel. Can you get a pic of the plug? A quick test for a coil control problem would be to disable the injector for cylinder 3 by unplugging it, pull the plug from the cylinder and put it in the wire, let the plug touch a good ground and start the car. you should see a decent spark. A cylinder leak test would be the next item to try.
Old 05-20-2016, 12:22 AM   #12
JerTM
JerTM's Avatar
Originally Posted by Moreair1 View Post
Have you checked your 02 sensors are operating correctly
O2s will not cause a misfire on one cylinder.
Old 05-20-2016, 12:05 PM   #13
JerTM
JerTM's Avatar
My college education, GM training, and decades of experience is all wrong. It's on the internet.
OP, don't bother autozoning the o2 sensor, it won't change the misfire on a single cylinder.
Old 05-20-2016, 12:17 PM   #14
Soybeanrice
Soybeanrice's Avatar
Drives: 2014 2SS/RS
I didnt see where he swapped the plugs or put in a new AC delco plug ... All I see is that OP inspected it and said the current plug was dark. Picture of the plug would really help.
Soybeanrice is offline   Reply With Quote
