Hey Camrads,
I am thinking on swapping the entire rear diff as it would be easier for me to install the whole unit rather than disassembling the unit and struggling with gear rings and pinions. I have a stock 3.27 (A6) rear diff, if anyone is going the FI route it would be an option for you. The car has 50K on it, diff oil has been changed about 1K ago. Diff has no problem, I just need to make the car faster. Looking to get 3.72/3.91 diff. May add some beer for the swap, not looking in spending any money for the swap. Of course I am considering only LOCAL Camaro SS owners. So if anyone is interested in this swap please let me know. I am located in DFW area, TX. Thanks!
may also consider 3.45 rear diff
still looking
![]() Drives: 1992 Red 25th Annversary RS Join Date: Jun 2009
I've got my stock 3.45 gears that only have 30k miles on them. Swapped them out with 3.91s a couple months ago
Sent from my SM-G900V using Tapatalk |
#6 |
It's just the gears, noticed you hadn't got any responses. I didn't know of you'd be interested in just a set of gears or not
#7 |
If I was able to install the gears by myself I would be interested in, thanks. ..the gears swap requires a special tools and some technical expertise..some free time and good hands ) I only have last item from the list. On a separate note if I find a good local shop with acceptable price I will get in touch with you. How much you would take for gears?
#8 |
$100 shipped?
#9 |
good deal for sure but let me check on whether i can use it on auto
#10 |
Ok, just let me know.
| Tags |
| gear swap, rear diff |
