Old 05-17-2016, 07:58 AM   #1
Derekk
Derekk's Avatar
Drives: 2010 Victory Red SS/RS
BMR 1" Drop Springs Issue - Ideas?
I had BMR 1" drop springs (BMR-SPO19R) installed front and rear on my 2010 SS. My installer is telling me -
"the rear springs are really short, to the point that when the suspension is hanging the springs come off of their upper perch. Every time you jack up the car you will have to line the spring up as you set it down."
He is a very experienced mechanic and definitely knows what he is doing. He has done this install before with Hotchkiss springs with no issues whatsoever.
Anyone have any comments, experience with this?
Derekk is offline   Reply With Quote
Old 05-17-2016, 08:02 AM   #2
Mike_G
Drives: 2010 2SS/RS
did he re-time the bushings? Suspension wont hang as low if done vs not. Just a thought.
Is there a part number on the springs to make sure they sent the right ones?
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs....
Use to have
2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's
Mike_G is offline   Reply With Quote
Old 05-17-2016, 09:30 AM   #3
Roasstum1
EbonyCamaro
Roasstum1's Avatar
Drives: Black SS 14
Hotchkis +1
Roasstum1 is offline   Reply With Quote
Old 05-17-2016, 11:10 AM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
There is something amiss with the Install as this is not a problem that I ever get a call about.
Roasstum, Our Springs are made by the same company that makes Hotchkis's, so that is not the situation.
Old 05-17-2016, 11:32 AM   #5
Night trained
Night trained's Avatar
Drives: 2015 camaro 2ss 1LE
I had the same issue. I used epoxy to hold spring insulators in place. I Did not need to use a spring compressor to reassemble assembly due to shorter spring.
Night trained is offline   Reply With Quote
Old 05-17-2016, 12:15 PM   #6
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Good Idea. And a Spring Compressor is really not necessary
