Old 05-19-2016, 07:56 AM   #1
Paolo
Paolo's Avatar
Drives: 2018 Camaro 2SS
High coolant temp
Hi everyone,so the last day i was cruising in traffic and while idling at a red light my coolant temp went to 242 degrees,and engine temp sensor got a litte over the center mark,should i be worried?
Paolo is offline   Reply With Quote
Old 05-19-2016, 07:58 AM   #2
608RS
608RS's Avatar
Drives: 2015 2ss
if you've never done a coolant flush yet, i'd recommend it. 6+years on coolant is near end of life.
608RS is offline   Reply With Quote
Old 05-19-2016, 08:09 AM   #3
Paolo
Paolo's Avatar
Yeah,never done it,i will as soon possible then,thank you,is there a reccomended brand for coolant?on the manual i have read about dexcool
Old 05-19-2016, 08:34 AM   #4
havelegs
havelegs's Avatar
Drives: 24 LT1 M
Mine was up to 215 the other day at a red light and 90 degrees outside.
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30
havelegs is offline   Reply With Quote
Old 05-19-2016, 08:48 AM   #5
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
that is good and will work great.
hrpiii is online now   Reply With Quote
Old 05-19-2016, 10:13 AM   #6
608RS
608RS's Avatar
Drives: 2015 2ss
Go by whatever is recommended in your manual like you said. I would also recommend doing a new thermostat too, given the age of your car. it's a cheap part and coolant will get drained regardless.
also, via italia!
Old 05-19-2016, 11:21 AM   #7
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
I have an L99 too. Does your tranny ever get up around 215 perhaps 220 as well? Mine does in slow moving traffic so was just curious when I saw you had a L99...
qcman is offline   Reply With Quote
Old 05-19-2016, 11:32 AM   #8
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
Before you swap the coolant you need to figure out what's causing it to overheat, because 7 year old coolant will not be the cause.
It's low on coolant from a leak or something has malfunctioned such as the electric fan. Something is wrong if it hits 240 degrees, unless you are idling in the desert with the AC on high I suppose.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 05-19-2016, 11:40 AM   #9
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
Watch out with Dexcool that stuff SUCKS! I've replaced intake manifold gaskets on every vehicle that came from the factory with Dexcool except my Camaro and Impala because they are too young still. If you switch make sure you get all of the Dexcool out though because that will gum up the cooling system.
Check out my build thread
Old 05-19-2016, 11:55 AM   #10
havelegs
havelegs's Avatar
Drives: 24 LT1 M
Not sure, I don't have a gauge to tell me. I would imagine it would get pretty high especially coming into the summer months where our temps in Austin could reach 110F on some days. The normal temp in summer is around 95-100, so I could surely see this running hot but I don't think I should be concerned as the fans will be blasting away, (blasting hot air on the hot engine)
Old 05-19-2016, 12:53 PM   #11
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
this! my malibu has 12 year old dexcool and works fine.
maddoggyusa is offline   Reply With Quote
Old 05-19-2016, 02:28 PM   #12
Swacer
Drives: 2018 GT350
Mine will go up to 219 highest on a hot day with AC on, but usually is 192-194 crusing.
My tranny temp under NORMAL driving conditions doesn't see over 190.
Off to the Dark Side
Swacer is offline   Reply With Quote
Old 05-19-2016, 02:36 PM   #13
two_wheel_mayhem
You should change it though
Old 05-19-2016, 02:48 PM   #14
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Agree with the two_wheel_mayhem advice. 250 degrees is around the boiling point of 50/50 mix of antifreeze and water at 14 PSI; you are getting in the danger zone of fluid loss. When it runs hot do you see the electric fans spinning fast on the radiator? Did you let the car completely cool off and then slowly remove the radiator cap to see if the coolant is at the top of the radiator neck? After that the next suspect on the list could be the thermostat.
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
