Old 05-19-2016, 06:04 PM   #1
failshift
Banned
Heatwrapped Intake
There are different opinions on what this will do. Whether it will trap the heat. Or help. So I'm going to test. At the worst I'm
Out $20. Before the blower/headers made so much heat under the hood it was raising my ambient temp reading and the IAT way over that. With just the headers. I was able to pull 1:1 ambient/IAT
Now with the blower it was much much higher. And I'm sure the LSX block won't help either. So i heatwrapped the tube. The CAI Inc is already a GREAT intake. And is crazy good at keeping the temp down. I just have too much for the ceramic coat to handle (I will be doing a good vent soon as well, to actually address the issue instead of cover it)
Tired of waiting trying to make it dry faster
Baked for 30min at 200* and the inside the tube metal
Surface was 114. And the outside was 100 flat
LSX376 SLP TVS2300 '13 1LE
Full front half protected by Xpel PPF
Instagram:@Failshift
603hp/547tq
1LE Owners Group:
https://www.facebook.com/groups/559684050767758/
failshift is offline   Reply With Quote
Old 05-19-2016, 06:40 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
I've pondered something like this..... Wondering what high boost IAT will look like compared to ambient.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 05-19-2016, 06:46 PM   #3
failshift
Banned
Old 05-19-2016, 07:15 PM   #4
flyer08
Drives: 2010 2SS/RS
Been wondering if something like this would work for hot Texas summers. Already have hood on order to get rid of some heat but need more help. Keep us updated
flyer08 is offline   Reply With Quote
Old 05-19-2016, 07:16 PM   #5
xXSicSicSicXx
Drives: 14 1LE
i just dont see how this will help since the heat is formed after the blower..
xXSicSicSicXx is offline   Reply With Quote
Old 05-19-2016, 07:29 PM   #6
failshift
Banned
Because the engine bay is super hot because of the headers and the blower.
Old 05-19-2016, 07:49 PM   #7
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Do you have the ADM scoop for your CAI?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-19-2016, 08:01 PM   #8
failshift
Banned
Apex yes
Old 05-19-2016, 09:32 PM   #9
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
I wouldn't expect to see much change due to the coating the cai intake tube has and since you have air flow coming from a apex scoop vs the stock cai location but I definitely will be waiting to see your results good luck
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 05-19-2016, 10:28 PM   #10
1KillerSS
1KillerSS's Avatar
Yea, I'm in for the results, but willing to bet all you'll notice is lower temps while idling. Driving down the road, I doubt will make any difference since your utilizing an air scoop.
Build thread
Old 05-20-2016, 01:49 AM   #11
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Curious since I'm still waiting on my intake to come back.
Old 05-20-2016, 05:06 AM   #12
thephoenix
Drives: 2010 Camaro RS 2LT
I heat wrapped the intake on my last car. It had a 2.0 turbo and the heat wrap made a huge difference, but I needed reflective tape over the heat wrap to really make it work well. The heat wrap kept ambient heat out and prevented heat soak, and the reflective tape kept the radiant heat from the flaming snail at bay.
thephoenix is offline   Reply With Quote
Old 05-21-2016, 12:58 AM   #13
failshift
Banned
Yes it appeared to help. Before I wa generating so much heat it was messing up the ambient. Now the ambient is spot on. It's moved back into the threshold of 1:1 while moving. And still kept it respectable while sitting at the light. I would say worth the $20 definitely.
Sitting a full cycle at a light
Driving at 60mph
603hp/547tq
1LE Owners Group:
Old 05-21-2016, 01:30 AM   #14
CamaroDreams76
Driving at 60mph
603hp/547tq
1LE Owners Group:
Glad that worked out, thanks for updating
