05-19-2016, 06:28 PM | #1 |
Drives: 2014 2SS M6 "CHRISTINE" Join Date: Mar 2014
VMAX Throttle Body AND CAI; Error Code?
Hey all,
I have a VMAX throttle body on the car now and I run an AEM hi-flo air filter in the stock air box setup. I have a CAI brand CAI and was wondering if I installed it would I get an error code? Would the car be running too lean? I was waiting to put on the CAI until I was just about to go to the tuner shop (Slowhawk Performance) for other upgrades, but have had some timing issues with scheduling. Anyone run this setup now? Thanks for any advice.
"But, House Mormont remembers. The North remembers! We know no King but the King of the North whose name is Stark. I don't care if he's a bastard. Ned Stark's blood runs through his veins. He's my king–from this day until his last day."
Mods: ARH headers and hi flow cats, VMAX ported throttle body, CAI air intake, Slowhawk Performance tuning |
05-19-2016, 07:29 PM | #2 |
Drives: 2014 SS 1LE Join Date: Apr 2014
You will be fine without a tune
05-19-2016, 10:32 PM | #3 |
Drives: 2013 Camaro SS Coupe L99 Join Date: Feb 2013
+1 you should be just fine an good luck with your future upgrades, you are going to a well respected shop.
05-19-2016, 11:15 PM | #4 |
BUMBL Z
You'll be fine
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
05-20-2016, 01:39 AM | #5 |
Too much is never enough!
Slowhawk will set you up! Great shop!
Slap that stuff on, you'll be fine, doubt you'll get any codes (would be super surprised if you do) Your fuel trims will change and you should get a tune so even if you get a code, Slowhawk will fix that for ya.
