Old 05-19-2016, 11:25 PM   #1
Scott@Bjorn3D
No oil pressure again
Well last night hopped in the car and pulling out into the street, ding ding ding No Oil Pressure. WTF, they just put in a new pump like 4 months ago. So turn off the car, and then try to start it again. Still no oil pressure. Turn it off and let it sit blocking the road. I had to at least get it out of the road so I start it up again and now oil pressure. So I get it out of the road and back it into the garage in case they have to flatbed it in the morning.
So this morning start it and it has oil pressure. Take it to dealer and after sitting there all day they tell me car is fine. They changed the oil and found no metal in the oil. They also cut open the GM oil filter and found no metal. The best thing they did notice was the check valve in the filter was off center and they think it may of gotten stuck.
I am really getting scared driving this car.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-19-2016, 11:41 PM   #2
Tenring
Tenring's Avatar
Drives: 2015 SS/RS M6 Commemorative
Wow hopefully is was just the filter!
Tenring is offline   Reply With Quote
Old 05-20-2016, 01:33 AM   #3
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
I know it's been beaten to death and I'm afraid to even ask because I don't want your thread to get jacked, but is the oil pump specifically a LS3 problem or L99 as well?
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 05-20-2016, 02:04 AM   #4
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Sounds like an oil pressure sending unit. Its a cheap part, I would replace it and see how it is. Next thing I would do is buy a manual Oil pressure gauge, then plug it in to see for yourself, next time it acts up. That is, if the new sending unit does not fix the problem.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-20-2016, 08:55 AM   #5
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
I know the L99 uses a different higher volume pump. I have heard it can affect the L99 but have never read of anyone reporting it here. The LS3 there have been lots of instances.
qcman is offline   Reply With Quote
Old 05-20-2016, 10:31 AM   #6
LT1Zob
LT1Zob's Avatar
Thanks
Old 05-20-2016, 11:22 AM   #7
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Do you have a catch can? Too soon?
gajagfan is offline   Reply With Quote
Old 05-20-2016, 11:23 AM   #8
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
This. If it's not the filter, I'd bet it's some electrical problem. The pump is probably fine... I don't think they can fix themselves.
maddoggyusa is offline   Reply With Quote
Old 05-20-2016, 11:39 AM   #9
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
If ya catch can, catch can, catch can!
If ya catch can, catch can, catch can, catch can, catch can!
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
http://www.camaro5.com/forums/picture.php?albumid=17325&pictureid=134228
sherob is offline   Reply With Quote
Old 05-20-2016, 11:40 AM   #10
Ledzepx
Ledzepx's Avatar
Drives: 2010 2SS Camaro 6sp.
Wtf!!!!
Ledzepx is offline   Reply With Quote
Old 05-20-2016, 12:47 PM   #11
Tenring
Tenring's Avatar
Anything further, got an update?
Old 05-20-2016, 01:27 PM   #12
Mr. Stacy
El Duderino
Mr. Stacy's Avatar
Drives: 2011 2LTRS Convertible
Hmmm... I need the tune.
I bowl. Drive around. The occasional acid flashback.
Mr. Stacy is offline   Reply With Quote
Old 05-20-2016, 01:48 PM   #13
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
great. Yours went out right when mine did last time. No more warranty for a new engine for me.
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 05-20-2016, 03:23 PM   #14
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
It's all starting to make sense. With so many oil pump failures, warranties would send GM back to insolvency! DENIED!
Moto-Mojo is offline   Reply With Quote
