Old 05-22-2016, 05:01 PM   #1
Dylan25
Drives: 2012 2 ss camaro 45th anniversary
ECS kit + meth
Everyone running an ecs kit i notice is running meth, i know it changes the temperatures and timing, but is it a MUST to run meth with the ecs kit? (sorry new to FI)
Dylan25 is offline   Reply With Quote
Old 05-22-2016, 05:05 PM   #2
Dyk-NO
Trust me I'm a Scientist.
Drives: My wifey ;P
NOPE depending on power level
"From ZERO to a Tire-Burning HERO!"
Mods: RotoFab CAI, SW Headers, HiFlo Cats, Borla Atak Catback, Nightfury Cam, Ported Heads,Intake,TB, melling pump, Morosso Oil Separator.
Dyk-NO is offline   Reply With Quote
Old 05-22-2016, 06:50 PM   #3
Unreal
Drives: 2006 Z06
No, but any FI system over 600rwhp should have some sort of added octane. That can be meth, race gas, e85, etc. Meth is the cheapest/easiest way to support the octane needs.
Nick
Corvette Z06 -1200ish rwhp
Old 05-22-2016, 07:06 PM   #4
Dylan25
I see, thank you
Old 05-22-2016, 11:21 PM   #5
TitusSS
Drives: ECS Supercharged 2010 SS
ECS kit plus meth here( Alky control). Had my tuner, Matt Sorian crank up the boost a bit, increase the spray. 11 lbs boost and 670 HP. In the Houston summer heat it runs a lot better than without the meth and I think it is worth every penny. YMMV.
TitusSS is offline   Reply With Quote
Old 05-23-2016, 12:37 AM   #6
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
+1 Dead on
Matt is the man! There is a small list of people that I would let touch my car, he is my go to guy, and my most trusted tuner.
OP if you do decide to go the meth route, make sure you have plenty of fail safes along with it.
This is just one option, you can wire it into a two step or a corn switch. The tuner can put fail safes into the tune as well.
http://www.aemelectronics.com/?q=pro...failsafe-gauge
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-23-2016, 04:39 PM   #7
Dylan25
Thanks a lot im still learning about Fi making sure I make the right choice the first time. I'll look into the fail safes too. Thanks again.
Originally Posted by 1KillerSS View Post
+1 Dead on
