Old 05-23-2016, 02:08 PM   #1
SoChrisB
SoChrisB's Avatar
Drives: 2012 Camaro 2SS/RS
Dropping Down In Pulley Size
I'm in the process of dropping down from the stock pulley size on my SLP Supercharger to a 3.4". I currently have the NGK TR6 plugs and more than one person recently told me I should get the NGK TR7s because of the higher boost. Is this true or can I stay with the TR6s. Appreciate the feedback.
SoChrisB is offline   Reply With Quote
Old 05-23-2016, 03:00 PM   #2
cc-rider
Drives: 2010 Camaro SS
Usually people go colder with plugs as they increase their power from boost. I think you got some bad advice. But I may be wrong here too...but I don't think you want to go hotter with the plug.
Those TR6's are pretty good plugs and well recognized as a good boost plug.
cc-rider is offline   Reply With Quote
Old 05-23-2016, 03:49 PM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
Hello Chris,
A change to a 3.4 pulley will require both a fuel pump upgrade with FPCM and an injector upgrade to ID-850s.
The 52 lb injectors will not support below 3.6 pulley.
Either way I recommend the fuel pump and FPCM combo.
TR7IX are recommended with a 3.4 and down.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 05-23-2016, 05:17 PM   #4
SoChrisB
SoChrisB's Avatar
Thank you. Appreciate the feedback.
Old 05-23-2016, 07:27 PM   #5
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
It also depends on the amount of boost your putting through it I would say (for most cases) a good guide to plug section is this 11lbs and under a #6 would work just fine, 12-18 #7 and so on and so forth. Now that's just a simple guide obviously each setup is different but you get the picture.
Trob85 is offline   Reply With Quote
