Old 05-24-2016, 02:06 PM   #1
mkhn2202
mkhn2202's Avatar
Drives: 2014 camaro 2SS RS,
Question Bottle heater and ZL1 fuel pump
Hi,
I installed a zex kit on my car about two weeks ago but I didn't buy the bottle heater. I did some research about zex heater and a lot of people says it's very slow. So what's the best bottle heater around? I also have questions about the Zl1 fuel pump install I have seen some people on the forum installed the pump from inside the car rather than taking the whole rear end out. I just want to make sure if it is safe? Because it's much easier to do it from inside the car. Right now I'm spraying 100 shots and I want to upgrade to 150 shots
mkhn2202 is offline   Reply With Quote
Old 05-24-2016, 03:28 PM   #2
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
I have tried 3 different brands of bottle heaters and like the one from Nytrex the best. Instead of being a pad, it uses a metal band. I found to heat up much faster. Cant help you on the pump install, had mine done at the dealer.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 05-24-2016, 05:37 PM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Yes, you can cut an access hole in your floor to R&R the pump. Check this thread out. Many people have done it, there is even a door you can get from Summit Racing to put in place of the hole, so that it looks like its supposed to be there.
http://www.camaro5.com/forums/showpo...4&postcount=94
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-25-2016, 03:35 AM   #4
mkhn2202
mkhn2202's Avatar
Do you have the link for door that Summit racing sell?
Old 05-25-2016, 01:21 PM   #5
1KillerSS
1KillerSS's Avatar
I couldn't find the link for the door that other people have used, but I did find a 6X6 inch access panel that may work.
http://www.summitracing.com/parts/aa...8530/overview/
Hope this helps. If that panel is too small, you will just have to do some searching for one that's bigger, I know that their out there.
Build thread
Old 05-25-2016, 05:26 PM   #6
Stubbsy
Stubbsy's Avatar
Drives: 2012 2SS RS
My mechanic just fitted a 6x6 to fit a Livernoise pump to mine, no problem getting the pump in but said the lock ring will not fit through.
Stubbsy is offline   Reply With Quote
