Old 05-24-2016, 11:24 PM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Question What do you think of these plugs??
These are BR7EF plugs since I plan on spraying it in the future. Fresh build cruised for about 30 miles today. How would you rate these plugs as far as being lean, rich, or perfect?
booneSS13 is offline   Reply With Quote
Old 05-25-2016, 10:33 AM   #2
booneSS13
booneSS13's Avatar
Nobody?
Old 05-25-2016, 11:38 AM   #3
lkurek
Drives: 2015 CAMARO
If these have ONLY 30 miles on them, Id say you are running moderately rich. That's a lot of soot buildup for only 30 miles.....which is maybe what, 2 gallons of gas?
The plugs may be too cold for your application too....if you plan on spraying it, then your "normal" running might be too cold.
lkurek is offline   Reply With Quote
Old 05-25-2016, 12:08 PM   #4
booneSS13
booneSS13's Avatar
Yep between idling and a half days worth of driving. I only used about a quarter tank of gas. I was under the impression the white on the plugs meant lean. Would that not be true?
Old 05-25-2016, 02:50 PM   #5
booneSS13
booneSS13's Avatar
I'm surprised out of 151 people there's not anymore input on this...
Old 05-25-2016, 02:59 PM   #6
Joey316g
Too many cars
Joey316g's Avatar
Drives: 2015 Camaro 2SS 1LE
Truth be told, they don't look too bad.. I used to do a ton of engine Dyno work.. Black soot is expected where it has formed.. Ground strap looks clean and a little pepper on the ceramic is what you are looking for.
2015 2SS/ Summit White RS 1LE NPP NAV Recaros
I got a big ass garage and I'm not afraid to use it.
Joey316g is offline   Reply With Quote
Old 05-25-2016, 08:37 PM   #7
booneSS13
booneSS13's Avatar
Cool that's good to know. This is my first time readingplugs
Old 05-25-2016, 09:25 PM   #8
Joey316g
Too many cars
Joey316g's Avatar
Anytime.. Any more questions just ask.. I may be new to this site but I've been in the automotive industry for over 20 years
Old 05-25-2016, 09:39 PM   #9
booneSS13
booneSS13's Avatar
Sure thing! That'sthe ttype of valuable experience we need on this site
Old 05-26-2016, 05:16 PM   #10
Badfinger
Badfinger's Avatar
Drives: 2010 2SS
You need to do more than 30 miles, but they look good or very normal to me not rich.
Badfinger is offline   Reply With Quote
Old 05-27-2016, 12:53 AM   #11
booneSS13
booneSS13's Avatar
Thanks that's a very useful chart. I'm going to do a WOT pass and shut it off and inspect the plugs after break in
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
Old 05-27-2016, 01:06 AM   #12
JD_Alaska
JD_Alaska's Avatar
Drives: 2013 Camaro SS Coupe L99
Plugs look good.
Install an air/fuel and log it, don't guess just know
JD_Alaska is offline   Reply With Quote
engine damage, heads cam, spark knock, spark plugs, tuning
