Old 05-25-2016, 01:36 AM   #1
1sick7
Drives: 2012 camaro convertible ss
Fuel System help- 750 rwhp
Need affordable fuel system any thoughts ? will I be deleteing fpcm?
1sick7 is offline   Reply With Quote
Old 05-25-2016, 02:01 AM   #2
avido
Drives: camaro ss\rs
The classic zl1 fuel pump and adm fpcm is what everybody's using for that power level. This is what I bought for my project,however it's just a matter of power. Are you sure you wanna stop at 750? I thought that power was enough for me but with hindsight,if I had to buy something right now I would go with a fore innovation double pump so I could be good for 1200..and it's a savagery. Of course the price is almost double but you are sure that you don't have to buy it double
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
avido is offline   Reply With Quote
Old 05-25-2016, 05:25 AM   #3
Yeager1990
Drives: 2012 2ss/rs L99
I have a zl1 pump and msd bap, skipped the adm fpcm because my builder from experience says I don't need it. I haven't found a dual pump setup that will handle e85 to your level but livernois has a dual pump might get there not sure on price
2012 2ss/rs L99
Agp twin turbo 51/61
full 3 inch stainless works retro chambered catback
Tuning by Greg Adams
Yeager1990 is offline   Reply With Quote
Old 05-25-2016, 07:54 AM   #4
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Go squash dual 450s (E85 compatible) or a Fore system and only do it once. Replacing my ZL1 pump now with the Squash duals for a 800+rwhp build on E85 / flex fuel setup.
Bildo is offline   Reply With Quote
Old 05-25-2016, 08:53 AM   #5
Unreal
Drives: 2006 Z06
Agreed with Bildo. Just do dual 450s with squash/fore.
Nick
Corvette Z06 -1200ish rwhp
Old 05-25-2016, 10:19 AM   #6
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
3rd the squash/fore system last system you'll ever need unless you go stupid crazy.
Trob85 is offline   Reply With Quote
Old 05-25-2016, 10:24 AM   #7
Gearheaded
Gearheaded's Avatar
Drives: 2014 SS
Anyone got a parts list for the squash system? I'm getting ready to build with a Whipple, and I want to make a parts list of everything I "need"
Toys:
2014 SS - TSP 235/239, CAI, LT's, 12.2 @ 115 ("SLOWLY" chipping away ET)
2000 Trans Am - Bolt-ons 13.0@110 (sold)
2009 YZF R1 - Race bike (road course)(totaled racing)
2008 YZF R6 - Race bike (road course)(still own)
Gearheaded is offline   Reply With Quote
Old 05-25-2016, 11:46 AM   #8
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Squash. First had zl1 with adm fpcm, then added a bap. Just do it right the 1st time
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 05-25-2016, 12:34 PM   #9
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Call Andy at Squash. He sells a complete kit that comes with everything you need but the labor.
Old 05-25-2016, 01:30 PM   #10
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
I have the Livernois dual pump setup, its the same as the LPE system that is also offered. I have managed to get over 800whp out of mine, but that's the problem....I want more.
So the choices are Fore, Squash, or AGP. AGP sells a system that will work for you. It's also affordable.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-25-2016, 02:54 PM   #11
AGP Turbo
Drives: All things Turbocharged
Our system starts with a Fore dual pump assm. and then we custom machine a number of fittings to make the whole thing super slick with a lot less potential leaks than other systems. -8 feed, regulator mounts under the hood, flex fuel sensor with all double o-ring QD type connections. Very few AN fittings, almost all o-ring.
AGP Turbo is offline   Reply With Quote
Old 05-25-2016, 04:11 PM   #12
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Fore Innovations twin pump FTW
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 05-25-2016, 06:07 PM   #13
Unreal
Drives: 2006 Z06
Was going to say, the AGP system is just a modified fore hat with all their own lines/fittings/etc. Its a slick setup. Can't go wrong with any of them.
Nick
Old 05-25-2016, 06:42 PM   #14
silvio207col
Drives: ROCH-SS
Dont make the same mistake i did. had zl1 pump, Adm fcpm, and BAP. finally upgraded to fore innovation twin pump.. doit right the first time brother. fore or squash Ftw
silvio207col is offline   Reply With Quote
