Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > ZL1 Engine, Exhaust, and Bolt-Ons
Old 05-26-2016, 05:04 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
Thumbs up AFCO Heat Exchangers for ZL1 @ Phastek Performance
NOW AVAILABLE!!
FREE SHIPPING @ Phastek Performance!!
The summer heat is approaching fast!! With summer right around the corner it will bring some horrible heat causing a drop in power to your ZL1!! The LSA is a great motor but has a hard time keeping cool once you start to put the pedal to the metal.
Keep your ZL1 cool with the AFCO heat exchanger, they have options with dual fans and with out fans. These exchangers have 3 times the collant capacity over the stock unit and AFCO claims little to no heat soak!!
The fans are controlled by the factory collant pump. When the factory pump kicks on the fans come on allowing them to pull more air past the fins to keep the exchanger temps down!!
Features:
  • All mounting hardware included
  • Full color installation instructions
  • Double pass design
  • Dual row 1.00” tube core
  • All aluminum TIG welded construction
  • Lasercut tanks and brackets
  • lower coolant temperature by as much as 25° F
  • Maintains lower coolant temperature
Dimensions:
Height = 11.35"
Width = 26.25"
Silver Heat Exchanger #80283NDP
Black Heat Exchanger #80283NDPB
Silver Heat Exchanger w/Dual Fans #80283PRO
Black Heat Exchanger w/Dual Fans #80283PROB
Sales@Phastek is offline   Reply With Quote
Old 05-26-2016, 10:00 PM   #2
Jkelley3209
Jkelley3209's Avatar
Drives: Savage ls
Will this fit a 2015 SS?
Jkelley3209 is offline   Reply With Quote
Old 05-27-2016, 01:18 PM   #3
Sales@Phastek
There would have to be some modification to fit the on the SS. Other then that it will fit.
Thank you,
Ricardo
Old 06-27-2016, 04:30 PM   #4
Jkelley3209
Drives: Savage ls
Thank you,
Ricardo
What modifications would have to be made?
Old 06-27-2016, 08:10 PM   #5
131LE
Drives: 2013 ZL1
pm price on silver with and w/o fans
2013 ZL1
131LE is offline   Reply With Quote
afco, heat exchanger, phastek, zl1, zl1 cooling
