05-27-2016, 12:07 AM | #1 |
Drives: '13 SS RS Join Date: Dec 2012
LED Lights Replacement all around (Interior + Exterior)
I am trying to replace all of my bulbs to LED white lights and looking for recommendations/part numbers for the ones listed below:
- Dome Lights - Rear Parking/Reflector Lights? - License Plate Lights What else can I change to white LEDs besides whats on the headlights and tail lights? Thanks!
2013 Camaro SS RS
05-27-2016, 07:20 AM | #2 |
Dome Lights -
AAC or DIODE (Both have options for Cool White LED's) Rear Parking (Reverse?) Go with AAC Reverse Lights License Plate Lights - Again AAC or Diode (Both Have Options for Cool White) Now as far as the part #'s go (This is bulb fitment) : Dome Light : 194, Or known as T10.. Reverse Lights : 194, Or T10.. (*I'll throw in this in case you meant this -Rear Tail Light(s) [4] : 3157, ...) License Plate Lights : 194, Or T10.. *Now as far as adding more WHITE* Headlights overall? Or do you just mean the projector - if that's the case Go with Switchback LED's (Front Turn Signals) they look great (;. Basically - They are on WHITE - but shine AMBER when you use your turn signal - then go back to WHITE. Hence the name "Switchback". Bulb Fitment is Part 3157. *In this case you're going to need resistors so you don't have hyperblinking* I can send you a video or picture of how I have mine installed. Moving on - More WHITE - Add Footwell Lighting (: I haven't done this, but I should...Anyways : http://www.diodedynamics.com/store/l...otwell-led-kit *Another addition is change out your fog lights, to Plasma LED (Just choose WHITE). ****ALL THINGS CONSIDERED**** You have an RS, make sure if the option is available for RS - get it. So Fog Lights for you in this case are P13W. Hope this helps (; . |
05-28-2016, 12:27 AM | #3 |
Thanks William.
Do you know which bulbs I need to replace the ones below? (circled in red)
2013 Camaro SS RS
05-28-2016, 11:20 AM | #4 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
This. LED replacement bulbs will not give enough light output to safely see.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
05-31-2016, 08:38 AM | #5 |
Drives: 1991 Z28, 2015 SS & 2017 SS Join Date: Aug 2009
Side Markers are an easy swap, uses the same bulb type as the map light, trunk and license plate lights.
