Old 05-27-2016, 01:33 AM   #1
Mach Schnell!
Drives: Chevy SS 2014 supercharged
Question 3-bar MAP sensor change on Whipple Supercharged LS3 -any change besides linear/offset
Question to those who changed the factory 1-bar MAP sensor on forced induction LS3: I am changing factory MAP sensor to 3-bar GM P/N 12592525, strictly for the purpose of displaying gauge & logging boost in hptuners. Other than changing scaling ("linear" = 312.5 kPa and "offset" = -11.25 kPa) parameters on Engine> Airflow> General > MAP is there anything else that I need to change? Note that I verified (I believe) that I have MAF-only tune by observing Engine> Airflow> Dynamic> Dynamic Airflow "High RPM Disable" =150 rpm and "High rpm Re-enable" =100 rpm. (This per Hptuners Thetuningschool instructions.) thanks.
Mach Schnell! is offline   Reply With Quote
Old 05-27-2016, 08:22 AM   #2
Unreal
Drives: 2006 Z06
Nope, you will be good to go.
I would look into getting rid of the maf only tune IMO.
Nick
Corvette Z06 -1200ish rwhp
Old 05-27-2016, 08:26 AM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
MAF only is never really MAF only, it still blends Virtual VE during throttle transitions.
Tuning both is best but only really affects operation below 3000 rpm.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 05-27-2016, 11:34 AM   #4
Mach Schnell!
Thanks Nick and Ted
Old 05-27-2016, 02:26 PM   #5
scv_guy
scv_guy's Avatar
Drives: 2010 Camaro SS
Can you elaborate on that, im currently running MAF only and the car seems to run great.
scv_guy is offline   Reply With Quote
Old 05-27-2016, 03:27 PM   #6
Unreal
Drives: 2006 Z06
Maf doesn't deal with low RPM well, doesn't deal with transitions well. I said the same thing for years, until I did my SD tune and didn't realize how much I was giving up. Throttle response, low throttle, all that is VASTLY improved. I went around for years saying MAF only is fine, then I tried SD and Hybrid and felt like an idiot.
Lots of tuners do MAF only because it is easy and quick, but it is never ideal.
Nick
Old 05-27-2016, 03:30 PM   #7
scv_guy
scv_guy's Avatar
Thank you for the input, I'll look into SD and or a hybrid tune
Old 05-27-2016, 03:45 PM   #8
JANNETTYRACING
On a 100% stock engine it won't help because all your Dyn air tables are already correct.
It is when you change cams, heads compression, intakes, headers etc that the Dyn air tables get out of whack and need to be calibrated for optimum low speed operation.
The Older computers were much slower and really need the dyn air tables to be perfect, these newer computers are much faster responding MAF and are not as sensitive.
Hope this sheds a little more light on the subject.
Old 05-27-2016, 05:10 PM   #9
scv_guy
scv_guy's Avatar
Yes thank you..One of these days I'll do a cam swap, not sure if I'm going to keep the VVT or do an LS3 conversion.
Old 05-27-2016, 07:14 PM   #10
Unreal
Drives: 2006 Z06
Even with the newer computers being faster, a tuner should be adjusting both IMO, and not just doing a quick/easy maf tune and sending someone on their way which is VERY common.
Nick
Old 05-27-2016, 09:27 PM   #11
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Now I'm considering buying this 3 bar.. hmmm
Nighthawk89 is offline   Reply With Quote
Old 05-27-2016, 10:21 PM   #12
scv_guy
scv_guy's Avatar
They are cheap, allow you to log boost and 5 min install. You will need to rescale your map settings
Old 05-28-2016, 11:02 AM   #13
JANNETTYRACING
Every boosted car should have one.
It is way more than just logging it.
The computer uses manifold pressure VS Fuel pressure to come up with a Pressure Delta which leads to final pulse width calculation.
Right now without the 3 bar, the computer is not seeing your manifold pressure so your injector pulse width calculations are way off, which also means your MAF calculation is way off, and your PE table is more than likely raped.
Ted.
