Old 05-31-2016, 12:51 AM   #1
Yeager1990
Drives: 2012 2ss/rs L99
AGP twin kit expectations
I bought this used from a member Fraxum. They are 51/61 Borg Warner turbos with .82 ar. I spoke with Kevin at agp and says I can make my power goals through my 6l80 with 93 octane (650rwhp) but fuel flow and octane are my limiting factor. I know e85 is outstanding for boost and some people don't like meth.
Question1: at about 8 psi on 93 with aggressive timing what could I expect horsepower wise
Question2: at 8psi on e85 with more aggressive timing and possibly more boost what could I expect
Question3: I would like to run 10 psi or higher depending on what my tuner can get out of it. I run 1/8 mile tracks and 17 inch mickeys 3.27 gears 3 inch exhaust what times could I expect high 6s possible
2012 2ss/rs L99
Agp twin turbo 51/61
full 3 inch stainless works retro chambered catback
Tuning by Greg Adams
Yeager1990 is offline   Reply With Quote
Old 05-31-2016, 12:53 AM   #2
Yeager1990
750rwhp is max goal later on down the line
2012 2ss/rs L99
Old 05-31-2016, 09:11 AM   #3
Unreal
Drives: 2006 Z06
8psi should do ~600rwhp
Maybe another 50rwhp on e85
High 6s would be beyond easy if you can hook and launch it. Going to need a stall for sure.
Nick
Corvette Z06 -1200ish rwhp
Old 05-31-2016, 10:46 AM   #4
JANNETTYRACING
JANNETTYRACING's Avatar
For Reference;
A stock L99 car puts down 330 RWHP, you can expect about 20-22 RWHP per lb of boost.
The amount of boost and timing you can run is Octane limited
E-85 is absolutely your best way to go if available to you all around you.
The more you spend on fuel system and fuel the more HP you can run safely.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 05-31-2016, 12:56 PM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
The kit you bought will produce more power than your expected goals, at 13psi, with meth, i put down 747.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-31-2016, 02:04 PM   #6
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
1: Thing with turbos is that you can make power with boost and not have to get overly-aggresive with timing. I got 652rwhp with 8# spring 91 octane (stock cam) - but I did have the fueling to do that easily.
2: About 700rwhp on E85, and you can crank up the timing. I added 6* with my setup (stock cam) - fueling will be a limiter for you until you up that capability.
3: I got 673rwhp at 10# on 91 (stock cam). Sub 7's 1/8th's are definitely in the future for you.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 05-31-2016, 05:42 PM   #7
Yeager1990
Ok all of you are who I wanted to hear from, I read almost all of your post to get my information been reading for like 3 years
2012 2ss/rs L99
Old 05-31-2016, 05:43 PM   #8
Yeager1990
2012 2ss/rs L99
Old 05-31-2016, 05:48 PM   #9
Yeager1990
Originally Posted by JANNETTYRACING View Post
For Reference;
Ted.
Thanks Ted yeah I'm going to run agp's dual pump with flex fuel sensor and id1000s on e85 I should be solid to 800rwhp if not more. I was going to settle for a zl1 pump and bap but don't want to chance the bap burning up.
I read somewhere that with a high stall converter a bap is a bad idea.
I'm on a stock rear end so hooking and booking is on the back burner until I can find a zl1 rear for decent price
2012 2ss/rs L99
Old 05-31-2016, 05:53 PM   #10
Yeager1990
I'm a newb drag racer so this much power is going to take some practice and getting use too
I feel like 8psi is pretty easy on the internals for driving around, I have the gofastbits boost controller as well I won't be disappointed in my power because I'm going form 380ish to 600ish should be a nice pick up and wicked sound
2012 2ss/rs L99
Old 05-31-2016, 05:54 PM   #11
Yeager1990
Does anyone know of any auto cars other than Kevin running this kit
2012 2ss/rs L99
Old 05-31-2016, 08:17 PM   #12
Unreal
Drives: 2006 Z06
There are tons of auto cars running it.
Stall and BAP isn't related, so not sure what that is about.
Teds probably done a few autos, Matt@FSP has done a few, RPM, LMR, Vengeance, etc.
Nick
Old 05-31-2016, 08:55 PM   #13
Yeager1990
Thanks waiting on Kevin to send me a invoice for the rest of my setup and I will install after manifolds are ceramic coated this week
2012 2ss/rs L99
Old 05-31-2016, 09:25 PM   #14
Yeager1990
I found a very reasonable deal on a alky control meth system with upgraded 4 gallon tank would it benefit me more even staying at 650rwhp for awhile
2012 2ss/rs L99
