Old 05-31-2016, 10:13 AM   #1
LBJ
LBJ's Avatar
Drives: 2012 camaro 1LS. M6
Wrapping my hood
I would like to wrap my hood I'm just curious how hard it be to do has anybody done it themselves
Mods..mrt v2. Cai intake v max throttle body. 20% windo tint & RX catch can Gianna 20in rims nitto 555 & afterburner tail lights RS halo head lights & gm heat extractor 4 pack gauges & panted heritage Grille & zl1rear sproler t5 splitter custom head rest
LBJ is offline   Reply With Quote
Old 05-31-2016, 10:44 AM   #2
Marlon1LS
Marlon1LS's Avatar
Drives: 2012 Camaro 1LS w/L99/TR6060
Not hard at all. I would suggest you have an extra set of hands to pull vinyl tight. And a hairdryer will do the job to help stretch around edges and to pull out any wrinkles descending on material you're using.
This would help you smooth vinyl as you lay. Or a creditcard but that may scratch vinyl.
L99/TR6060 1LS swap in the making.
Marlon1LS is offline   Reply With Quote
Old 05-31-2016, 11:58 AM   #3
LBJ
LBJ's Avatar
Thanks. hopefully it works out me
Old 05-31-2016, 09:32 PM   #4
FastGirl
FastGirl's Avatar
Drives: 2013 2LT/RS
Get one of those Plastic things with the soft material, will be very helpful as credit card, will probably cause damage. also, a sharp razor blade, to cut the excess off, nice and clean!
Good Luck :-)
FastGirl is offline   Reply With Quote
Old 06-01-2016, 06:42 PM   #5
camaro2ss/rs
Drives: 2ss/rs
are you doing carbon fiber
camaro2ss/rs is offline   Reply With Quote
Old 06-01-2016, 07:30 PM   #6
LBJ
LBJ's Avatar
Yes That's my plan
Old 06-02-2016, 08:59 AM   #7
Oogabooga
Oogabooga's Avatar
Drives: 2011 Camaro 2LT Satin Black
I would use 3M Primer 94 on the edges. Also. you need to post heat the wrap especially on the edges so it looses its memory. I post heat to 180-200 degrees using a laser thermometer and heat gun.
Oogabooga is offline   Reply With Quote
Old 06-02-2016, 09:07 AM   #8
camaro2ss/rs
Drives: 2ss/rs
you doing 3D CARBON FIBER OR THE 4D CARBON FIBER.. if you do the 4D fiber let me know i have done it before and can tell you what not to do with it
Old 06-02-2016, 12:35 PM   #9
LBJ
LBJ's Avatar
I was thinking about 3d..my only concern is I have a heat extractor & I'm concerned about the wrap being cut ware I cut out the hood ..maybe dubbing up in that area
Old 06-02-2016, 01:32 PM   #10
Oogabooga
Oogabooga's Avatar
Use knifeless tape.
Old 06-02-2016, 02:18 PM   #11
Marlon1LS
Marlon1LS's Avatar
You could wrap over extractor, heat edges and tuck with a card then cut inside under edges with exacto knife or something similar.
Old 06-02-2016, 07:15 PM   #12
LBJ
LBJ's Avatar
I just need to do more research before I start
Old 06-03-2016, 04:30 AM   #13
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
vent should be easiest part. Just take it out when you do it and voila
JT Camaro is offline   Reply With Quote
Old 06-03-2016, 08:03 AM   #14
1LEJNG
Drives: Red Hot 2014 1LE
Hood Wrap
Remove the heat extractor first. Just takes minutes
1LEJNG is offline   Reply With Quote
