Old 06-01-2016, 09:28 PM   #1
dshakhba
Drives: 2015 Camaro 2SS/1LE
Camaro 1LE Strut, axle and Wheel Hubs
Hi Everyone I have a 2015 Camaro 1LE. My cars in the shop and the GM parts guy is having some issues getting correct 1LE specific Parts as it is not giving correct P/N's with the VIN.
I gave him the ZL1/1LE Registry part numbers but they dont match with the actual 1LE part numbers on the car.
The front Strut that came was P/N 22812985 (Passenger side). Online it shows it reversed (Driver side as being this part number when in reality its passenger side).
The only thing I need is a passenger side rear shock P/N, the front and rear passenger side wheel Hubs P/Ns and passenger side Axle P/N.
Would anyone that knows please tell me the P/N's for those 3 items.
I really appreciate any help!
Thanks
dshakhba is offline   Reply With Quote
Old 06-01-2016, 11:47 PM   #2
dshakhba
Anyone?
Old 06-02-2016, 02:37 AM   #3
Splat
Splat's Avatar
Drives: 2012 1SS M6 IOM
Thats strange, if you have a true 1le, then your vin number should pull up all parts that were placed on your car.
Only other opt. I see is, using another 1le vin number.
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI
Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018.
Splat is offline   Reply With Quote
Old 06-02-2016, 10:39 AM   #4
dshakhba
Its definitely a 1LE....even my VIN calls out for a 1LE package....but a couple of the parts came incorrectly and I don't trust the GM parts guy anymore. So just wanted to double check.
Old 06-02-2016, 10:52 AM   #5
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
May I ask why you are needing these parts replaced on such a new car?
gajagfan is offline   Reply With Quote
Old 06-02-2016, 11:12 AM   #6
Scotty D2014
Drives: 2014 SS1-1le Crystal red metallic
Because needless to say
Parts do fail ! Even newer cars
Scotty D2014 is offline   Reply With Quote
Old 06-02-2016, 12:32 PM   #7
gajagfan
gajagfan's Avatar
Parts do fall ! Even newer cars
I find it hard to believe that those parts failed on a 2016 at this point without some outsides circumstances involved (crash, mods, etc.).
Old 06-02-2016, 12:38 PM   #8
PlatinumIce
WILD CANADIAN HEARTBEAT
PlatinumIce's Avatar
Drives: 2014 2SS 1LE RS, 2014 ZL1& 2024 ZL1
Here is a list that I have for various 1LE parts numbers. Hope you find something in there
1LE Part Numbers:
  • Strut Tower Brace (LT, SS, 1LE) - 22756880
  • Wheel Hubs (ZL1, 1LE) (4) - 25954415
  • Front Coil Spring (SS, 1LE) (2) - 92245257
  • Front Strut (1LE) (passenger side) - 22812984
  • Front Strut (1LE) (driver side) - 22812985
  • Front Sway Bar (1LE) - 22812946
  • Front Sway End Link (SS, ZL1, 1LE) (passenger side) - 22842515
  • Front Sway End Link (SS, ZL1, 1LE) (driver side) - 22842516
  • Rear Shock Mount (ZL1, 1LE) (passenger side upper) - 22836734
  • Rear Shock Mount (ZL1, 1LE) (driver side upper) - 22836727
  • Rear Coil Spring (SS, 1LE) (2) - 92195466
  • Rear Shocks (1LE) (2) - 22812987
  • Rear Sway Bar (ZL1, 1LE) - 22786260
  • Rear Sway Bar Endlink (SS, ZL1, 1LE) (2) - 22761221
  • Rear Lower Control Arm (SS, ZL1, 1LE) (2) - 20942237 (Needed for 2010-2011 car conversion)
  • Rear Toe Link (ZL1, 1LE) (2) - 22845487
  • 3.91 Gears only ( 1LE ) - 22813040
  • Hood (SS 1LE) - 22972003
  • Deflector , Hood Air (SS 1LE) - 23180572
  • Spoiler (SS 1LE RS PKG) - 22946169
  • Tail Lamp (LED RS PKG) - 23161674, 23161675
  • High mount Stop - 23172447
  • Rear Fascia lower without NPP - 22829476
  • Rear Fascia upper with backup sensors - 23164145
  • Rear Fascia lower with dual mode - 22829477
  • Rear Fascia upper no backup sensors - 23164146
  • Front Fascia with RS PKG - 22997721
  • Grille Front upper without RS PKG - 22829516
  • Headlamp with RS PKG HID HALO - 23187857, 23187856
  • Emblem Front Grille - 22831295
  • Plate Front Grille EMB BKG with RS PKG - 22829512, 22829506
  • Scoop, Hood Air Black - 22828242
  • Front Fog Lamp - 22830038
  • Front Fog Bezel - LH-22829542--RH-22829543
  • Front Upper Grille Chrome Trim RS PKG - CTR-22829525--RH - 22847642--LH - 22847641
  • Wheels 20x10 Black ( ZL1-1LE ) - 22798741
  • Wheels 20x11 Black ( ZL1-1LE ) - 22798743
  • SS/1LE with 1SS with Black interior,so these are Black "NON" heated seat cover numbers.
  • Bottom drivers side - 23127746
  • Back drivers side - 23127745
  • Bottom passenger side - 23128319
  • Back passenger side - *No part number listed yet*
  • SS/1LE with 2SS with Black heated Recaros
  • Bottom drivers side cover - 23128297 - List is $876.73
  • Back drivers side cover - 23128291 - List is $1,317.85
  • Bottom passenger side cover - 23128315 - List is $876.73
  • Back passenger side cover - 23128308 - List is $1,317.85
700/633 91Octane Street Tune=750/670 VP109 Race Tune TVS2300 Heartbeat SC,ADM Dual Fuel Pumps/ Module, BRM lowered 1", performance rotors, hawks pads, SS Braided lines, GT-14cam, 78mm pulley, AR LT Headers, Cat Deletes, Borla S catback, tinted, 1/LE emblems, 65lb Injectors, Elite catch can,dual valve springs, titanium retainers, super conductor wires and insulators, Robo Fab CAI, Oversize intercooler reservoir, Oracle ghost side markers, Black out Bowties & SS,ZL1 splash guards, Michelin PSS. Built and tuned by Davenport Motorsports (WILD1LE)
PlatinumIce is offline   Reply With Quote
Old 06-02-2016, 02:28 PM   #9
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
The vin number will not show if the car is a 1LE. The 1LE is an option on the SS. This vin will identify if the car is a 1SS or 2SS. Check the service tag in the trunk for the 1LE option code.
Old 06-02-2016, 03:11 PM   #10
JusticePete
Drives: Camaro Justice
There is no functional difference in the rear struts, left or right.
PN 23115372
Old 06-02-2016, 04:13 PM   #11
dshakhba
Thanks Pete!
PN 23115372
Old 06-02-2016, 04:14 PM   #12
dshakhba
The problem is some parts on here are wrong for some reason. example: the Hubs below are for a Z28 I think, My vin shows different P/N. Also P/N 22812985 calls out for a driver side Strut when in reality it is passenger side when talking with GM.
1LE Part Numbers:
Old 06-02-2016, 04:18 PM   #13
dshakhba
My father got cut off and scraped and it was a rainy day....car spun out with stock f1's and hit a curb. Some damage to the suspension and changing some parts as a precaution.
Old 06-02-2016, 04:26 PM   #14
dshakhba
According to this: http://www.***********.com/1le-specs-2015.php
my Vin number has a J as the 5th number which calls out a 2SS1LE
1le, fe6, suspension
