![]() Drives: 2010 Camaro RS Join Date: Aug 2015
What is your opinion on these break pad/disk kit?
Hello, I've been wanting to buy a brake rotors(drilled and slotted) & pads kit for a while. I found this pair for my 2010 RS. Do you guys think its a good buy or do you guys other suggestions about other kits?
http://www.ebay.com/itm/Brake-Rotors...lWjWX5&vxp=mtr what im looking for is a good set around the same price too. |
A lot depends on what your going to do with the car. I've read drilled rotors often crack under hard use but slotted are ok for the street or track....
Orange Krush II
NZ Camaro. New Zealand
Drives: 1968 camaro. 2010 2ss Camaro Join Date: Dec 2012
I would just go for slotted and dimpled, less chance of cracking.
