Old 06-03-2016, 08:57 AM   #1
MonroeZ28
Drives: 15 z28 white
Harness for BK Bar
Is a 4pt harness the only thing that works with the BK harness bar? Just picked up a BK bar yesterday and want to make sure 4pt is the only option. Im only doing HPDEs not doing any racing with the car.
MonroeZ28 is offline   Reply With Quote
Old 06-03-2016, 03:50 PM   #2
JTRATX
Drives: 17 SS 1LE, 14 Yukon Denali
Yes, unless you add a tank plate.
JTRATX is offline   Reply With Quote
Old 06-04-2016, 06:31 PM   #3
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Yup, gotta find some type of tank plate. Good luck, I've currently got two thread on here looking for someone making them, and little luck so far. They area fairly simple item, so I think if you found a machine shop/metal fab shop that was willing to make a one off design, if would be fairly easy.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 06-04-2016, 06:53 PM   #4
JusticePete
Drives: Camaro Justice
Many groups are moving to 5 or 6 point harnesses only.
You can use these Simpson eye bolts, but you need to double up on the washers, one on top and one on the bottom.
http://www.summitracing.com/parts/si...0qUaAlUx8P8HAQ
http://www.summitracing.com/parts/si...gekaArnP8P8HAQ
These for the lap belt.
http://www.ogracing.com/brey-krause-...lt-gen5-camaro
Old 06-04-2016, 08:36 PM   #5
Spyglass
Drives: Too many
Depends what org you go with.
Spyglass is offline   Reply With Quote
Old 06-04-2016, 09:52 PM   #6
Og Neon
Lover of Speed
Drives: 2018 ZLE
What groups are going that way? Most seem to only allow 5/6 points if you have a cage. So that implies they want cages too for HPDE?
Og Neon is offline   Reply With Quote
Old 06-04-2016, 09:55 PM   #7
JusticePete
OPTIMA for one. Three point factory belt. No four point harnesses. Five or six point if you choose to wear a harness. Harnesses can be mounted to a HB or cage.
