Old 06-04-2016, 03:25 AM   #1
todd69gs
todd69gs's Avatar
Drives: 2014 Crystal Red 1LE 2SS
How much supercharged rwhp before high flow cats melt?
What's the safe limit for high flow cats on a supercharged ls3? I've read about meltdowns and I am curious.
.....and for guys that have them removed how bad is the fuel smell?
todd69gs is offline   Reply With Quote
Old 06-04-2016, 06:23 AM   #2
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
I'm at 625rwhp with no issues (ARH cats), but also depends on how you drive, your tune, and other mods (like stock cam or not)
POWERFREAK is offline   Reply With Quote
Old 06-04-2016, 07:02 AM   #3
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
The common belief is around the 600s for cats. I can say I have personally not seen an ARH cat melt. I don't know the manufacturing process but they have proven to be a little better most from what I've seen. I know this is and has been a huge concern for many for a long time.
I use an inspection camera to check cats as well as numerous other components. Frquent checks can give you an early warning to any potential problems.
UNRIVALED SS is offline   Reply With Quote
Old 06-04-2016, 07:18 AM   #4
todd69gs
todd69gs's Avatar
I guess how you drive would dictate a lot as well. If you're at the track with lots of heavy exceleration for extended amounts of time that can't be good for the cats. Makes sense.
Old 06-04-2016, 07:26 AM   #5
POWERFREAK
I.AM.
POWERFREAK's Avatar
Yup, lots of track and dyno time wouldn't help.
Old 06-04-2016, 09:24 AM   #6
Slowhawk
Drives: 1999 Trans Am
I've seen pretty much all of them push back. Usually 550+ hp. Some don't but I would not risk it.
Slowhawk is offline   Reply With Quote
Old 06-04-2016, 01:31 PM   #7
cc-rider
I tried to go catless. Couldn't stand the stink. I put on some Eastern Catalytic high flows. Not too many miles yet. We'll see how they hold up.
cc-rider is offline   Reply With Quote
Old 06-04-2016, 04:50 PM   #8
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
Mine melted at 655
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 06-05-2016, 08:58 AM   #9
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
From my understanding, its more about the tune, than the power.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 06-05-2016, 09:45 AM   #10
Dirtdog
Pro Hide n Seek Player
Dirtdog's Avatar
Drives: 2010 SS LS3/LSA 620whp/630tq
Send a message via AIM to Dirtdog
all I smell with no cats is speed. hot nasty speed.
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC
Dirtdog is offline   Reply With Quote
Old 06-05-2016, 12:47 PM   #11
Kopterman
Kopterman's Avatar
Drives: 2014 Bright Yellow 2SS/RS
So if I plan to go 650 to 700 whp I should not get cats with my headers. Correct?
Kopterman is offline   Reply With Quote
Old 06-05-2016, 12:50 PM   #12
Unreal
Drives: 2006 Z06
IMO, that is correct.
I wouldnt risk it, as a melted cat can easily take out a motor.
Nick
Corvette Z06 -1200ish rwhp
Old 06-05-2016, 03:20 PM   #13
1KillerSS
1KillerSS's Avatar
If you don't have to run them, I would't run them. Personally, I love the smell.
Build thread
Old 06-05-2016, 07:25 PM   #14
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
I ran OBX cats for about 2.5 years, at 600+RWHP, and when I finally decided to punch them out, due to all the "melted catalyst" threads, there wasn't a single hint of any issue with the cats. Granted, the car doesn't live at the track, as its my daily driver, but it does see spirited WOT runs at least in the first 2-3 gears, almost daily.
I, also, love the smell...especially 108 Octane! It smells intoxicating!
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
