BUMBL Z
Nitrous on minor bolt-ons/dyno tune
I'm toying with the idea of getting a kit for a 100 shot of nitrous. I currently have long tubes with hi flows (will probably gut the cats), 3" cat back, vararam intake, ported throttle body, and dyno tune. I keep reading that on a stock platform, a 100 shot should be fine, but that dyno tunes tend to add in a lot of timing, and nitrous reacts better/more reliably by pulling timing in the tune instead. Is this something I should be conferring with my tuner about, or should I be able to get a kit, bolt it up and be good to go? Just trying to gather more information before I pull the trigger on it
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
BUMBL Z
Nobody?
#3 | |
Too much is never enough!
Why don't you go with a turbo or supercharger? I was looking at going the NOS route and its not much cheaper than a turbo setup. After spraying a couple times you have to fill the bottle up again at $60. That is going to get expensive over time.
Drives: 2010 2SS/RS Join Date: Jun 2009
Yep, after about $2500 for parts to do it right, plus install if you can't do it yourself, and $60 a fill....adds up quick
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
You can get a timing retard box and will run normal when system is off and soon as you arm it the box will tell your ecm to pull a preset amount of timing that you choose upfront. For a 100 shot, typically 4-5degrees will be pulled.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
#7 |
You can do a 100-150 shot nitrous outlet kit with extra goodies for $1500 or less. Bottle fills vary.. In my area $35-40
#8 |
BUMBL Z
Kit with a 15lb bottle I can score just under a grand brand new. Install seems straight forward, just with some wiring, the plate for the throttle body, and then the bottle lines. Nitrous around here, if I'm not mistaken, runs around 3 bucks a pound, so about 45-50 bucks for give or take 10-13 runs (if i'm averaging 100 shots, just an estimate, i read you could get about 10 shots of 100 with a 10lb bottle). Not trying to tilt the scale in my favor, just trying to learn and see if this could be a good idea. That timing retard box sounds like a solid idea should I venture down this road.
#9 |
He can but that's like buying FI and not,upgrading the injectors. To do it right need more than the basic kit including stand alone, lnc2000, etc. Then Do you want a remote opener or you just going to drive around with it on or off? To get all those runs do you buy a nano or do you buy a second bottle for when pressure drops? Goes on and on and really adds up fast which we both know
#10 | |
http://www.lingenfelter.com/product/...l#.V1TesvkrLb0
#11 | |
BUMBL Z
https://www.msdperformance.com/produ...ols/parts/8680
#12 |
BUMBL Z
Bumping this. Any recommendations on kits/brands? I was looking into nitrous express's 15lb bottle kit
#13 | |
![]() ![]() Drives: 2015 1SS, 1LE, Recaro, NPP Join Date: Apr 2014
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor) 647 RWHP 723 RWTQ (150 Shot) 12.1 @ 117 (Motor) 11.7 @ 129 (Nitrous) Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports Youtube Channel: Click Here Last edited by damian559; 06-15-2016 at 01:51 AM. |
#14 |
I've got my kit up for sale. Pulled it off Sunday
Complete Nitrous Outlet plate kit with 2.5gal standalone fuel system. $1800 obo Comes with heater, 2 10lb bottles, nitrous express RPM/WOT window switch, 400hp solenoids, purge kit, all relays, lines, aeromotive regulator W/oil filled pressure gauge, walbro 255 pump, and bottle heater.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
