Old 06-04-2016, 04:45 PM   #1
LS3_Dave
LS3_Dave's Avatar
Drives: 2014 2SS/RS LS3 Red Hot
Cleaning Engine Bay
So my engine bay is getting a little dirty, and I wanted to get any tips on cleaning it. Everything is completely stock, no aftermarket CAI or anything and the engine cover is still on. I've read that using a hose is fine and I just want to make sure that's okay before I try it, I also have Meguiar's "mirror bright" detailing spray and wanted to see if that would be okay to use as well.
LS3_Dave is offline   Reply With Quote
Old 06-04-2016, 07:08 PM   #2
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
I am not a fan of using any water in the engine compartment. Too many very expensive, sensitive electrical stuff. I will use Windex, spray it on a paper towel and wipe. Spray it on an old tooth brush for the dirtier areas. I would not use Meguiars mirror bright in your engine compartment. Only use a pure 100% silicon spray.
http://www.amazon.com/CRC-05074-Sili...+silicon+spray
I use it on my hoses, spark plug wires, any thing black plastic like fuse covers in the engine compartment.
Dimitrim is offline   Reply With Quote
Old 06-04-2016, 07:10 PM   #3
bigwayne3000
Drives: 2011 Camaro LS
Since everything is stock and you don't need to worry about any open CAI or anything, feel free to go at it with water and soap. I used Adams all purpose cleaner myself but you can use whatever you want. Everything is pretty well sealed in terms of not needing to worry about water damage, I just wouldn't use high pressure and just use a small stream. YOu don't need to go crazy with the water. You could also just use a rinseless wash like Adams rineless wash which you just spray on and wipe off without the need for water. Personally I'd give it a good water cleaning first then do the follow ups with the rineless stuff as needed.
bigwayne3000 is offline   Reply With Quote
Old 06-04-2016, 07:11 PM   #4
bigwayne3000
Here's a good video
Old 06-04-2016, 07:45 PM   #5
CO2010ss
CO2010ss's Avatar
Drives: 2010 ss/rs
I use the presoak cleaner then follow with the spot free rinse at the local self serve car wash and have for alot of years on all my cars with no ill effects, there is nothing under the hood that don't get wet when driving in a rain storm that will with a hose. as long as you don't use the hi pressure you will be fine.
2010 2ss/rs ls3 dynatech longtubes/exhaust, CAI intake, mgw short throw, pfadt coils, ds i1000 tuned by dynosteve, taylor 409 race wires, elite catch can, bfg comp 2 tires,
CO2010ss is offline   Reply With Quote
Old 06-04-2016, 08:00 PM   #6
Dimitrim
Dimitri
Originally Posted by bigwayne3000 View Post
Here's a good video
Most people have hard water, a lot of calcium in it. When it dries it will leave spots every where.
Old 06-04-2016, 08:34 PM   #7
Mike J
Mike J's Avatar
Drives: 2015 Topless Btch RS
Showed the vid to wife she seems to think I need to use a boars hair brush myself.....not impressed
Mike J is offline   Reply With Quote
Old 06-05-2016, 12:36 PM   #8
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
I've had my SS for almost 6 years with 52K miles on it. I always wipe the engine compartment after I wash it, which isn't very often, because it doesn't get very dirty. Since I wipe it, I don't need to hose it down.
sscamaro is offline   Reply With Quote
Old 06-05-2016, 01:36 PM   #9
49North1LE
Drives: 2015 2SS/RS 1LE G7C,
Compressed air will blow any water that finds a hiding place or could sit and form water spots. I always give the engine bay a good blast after rinsing.
49North1LE is offline   Reply With Quote
Old 06-05-2016, 02:24 PM   #10
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Like others, I wipe my engine compartments/bays down at least once a month, so I have no need to hose them down. I usually just get a rag damp and wipe everything down; I follow this by spraying a little detailer on another rag and wiping down all painted and plastic areas. If an area does get a little grimy, I'll spray that area with a little Simple Green first. Have done this for years.
Old 06-05-2016, 02:36 PM   #11
LS3_Dave
LS3_Dave's Avatar
Awesome thank you all for the great tips!
Old 06-05-2016, 02:57 PM   #12
Tenring
Tenring's Avatar
Drives: 2014 2SS/RS - SIM
Here's a good video
Video has good info, but would be better if she was wearing a bikini
Tenring is offline   Reply With Quote
Old 06-05-2016, 03:52 PM   #13
Mr. Stacy
El Duderino
Mr. Stacy's Avatar
Drives: 2011 2LTRS Convertible
The video was nice. I would let her tickle my engine area with her little nut brush but I wouldn't let her clean my engine compartment.
If you stay up with it, should just be a simple wipe down like Welker describes above.
If it got away from you and is really bad, then a dedicated engine pre-clean product to loosen the dirt and a VERY light rinse (cover your CAI etc.). Then after it dries, or towel dry, use the method above.
JMHO
I bowl. Drive around. The occasional acid flashback.
Mr. Stacy is offline   Reply With Quote
Old 06-05-2016, 06:09 PM   #14
Glintify
Glintify's Avatar
Drives: 2014 Camaro 2SS/RS
I used simple green mixed with water and scrubbed with a brush everywhere and then dried it with a microfiber towel . Did the job well
Speed is Life..
Glintify is offline   Reply With Quote
