06-05-2016, 10:26 AM | #1 |
Drives: 2013 2SS/RS Join Date: Mar 2014
How to make the 12 volt socket always powered?
I have a dashcam that I would like to run all the time when I am not in my car, but when I turn the car off the sockets lose power, and the dashcam turns off.
06-05-2016, 10:41 AM | #2 |
Drives: 2012 SS 45th Anniversary LS3 Join Date: Aug 2014
You'll need to wire it straight into the fuse block. I used a tap-a-circuit on the fuse for the trunk release. It's always powered. Realize that you will drain the battery if you do not use a power monitor like PowerMagic pro. This will allow you to set a limit to turn the camera off after a set time and if the battery voltage drops too low.
45th anniversary mods: CAGS delete, SW muffler delete, JBL shorties, Solo cats, strut tower brace, clutch/brake reservoir separation kit, Tick clutch bleeder, DRL harness, LED DRLs, elite catch can, ZL1 front grill, VTC, Rotofab CAI, blackvue dash cam, hurst billet plus 2, Eibach lower springs Ans anti-sway bars, Koni struts, tuning by DynoSteve
1969 corvette L46 coupe: ... Mostly stock Past cars: 1967 corvette L79 coupe 1999 corvette FRC 1968 camaro RS |
06-05-2016, 10:58 AM | #3 |
CamaroFans.com
Pop out this 4 prong Relay and replace it with a Jumper (this jumper only fits one way catercorner across).
Your 12v receptical on the console will remain hot. Also, anything connected to the two 20 amp spare fuses (#17 & #18) next to it will remain hot as well. I believe Diode Dynamics carries these jumpers for a couple bucks. |
06-05-2016, 11:02 AM | #4 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
Any one ever think about a Powered outlet in the
Trunk. Say in case u wanted to pump up a tire.
Hot Wheels Emblems and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills, Hot Wheels door Sills.
06-05-2016, 11:06 AM | #5 | |
Is anything else affected by removing the relay and installing the jumper? Thanks! EDIT: I can't find that part on diode dynamics. What is the correct name of the part? |
06-05-2016, 11:14 AM | #6 | |
CamaroFans.com
I also looked on their site and didn't see it but I'm pretty sure the guy who gave me mine gets his there. I will double check with him. He's getting me a different one that makes the one inside the console hot because my radar detector is connected to one of those 20 amp fuses and I don't want it on all the time. I need one hot for a wired GoPro. |
06-05-2016, 11:16 AM | #7 | |
06-05-2016, 11:18 AM | #8 | |
CamaroFans.com
06-05-2016, 11:24 AM | #9 | |
06-05-2016, 12:14 PM | #10 | |
CamaroFans.com
EDIT: I found these guys had it with cheaper shipping. https://nightowlleds.com/console-fus...r?search=jumpe |
06-05-2016, 06:57 PM | #11 | |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
this won't drain your battery.
06-05-2016, 07:10 PM | #12 | |
^This. You can also use https://www.blackboxmycar.com/produc...c-pro-blackvue But I would not just plug the camera into a port that has 12 volts constantly. You are asking for trouble.
08-31-2016, 05:27 PM | #13 |
9 Year USMC Vet
Drives: 2014 1LT black on black Join Date: Nov 2015
Will the jumper cause the battery to drain just sitting there, or only if I have something plugged into the 12v port by the shifter?
A lot of stuff done so far to make it look better and be more fun to drive.....
08-31-2016, 05:54 PM | #14 |
I installed mine a couple months ago, and it's working great. My battery doesn't die or anything.
I ordered this one http://sjmautoprod.com/5th-gen-camar...rt-jumper.html |
