Old 06-08-2016, 05:22 PM   #1
crc91
crc91's Avatar
Drives: '14 1LS
LFX cams
I know there are a few people out there with the LFX cams. I tried searching on YouTube for some sound clips of them. I'd love a choppier idle I think it sounds great. I did find a Holden with some mace cams it's purple and sounds mean! But I'm not sure if that model had the LFX or another engine variant. Would really love to hear some one's ideal if they have cams. I know they've been a pain in the ass to tune but maybe some one like overkill can figure them out and get some decent power out of them. Any thoughts? Ideas? I'm really tempted to buy some.
Patiently waiting for my 2023 SS 1LE
crc91 is offline   Reply With Quote
Old 06-08-2016, 05:54 PM   #2
derek1387
Drives: 2015 1LS Red V6
nope....worthless right now. Nobody can seem to get a decent tune on them, and MACE hasnt been helping at all. not worth the money and labor for them yet. Ghosted and I are working on a few things though...so be on the lookout!
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 06-08-2016, 09:26 PM   #3
Flotek
Flotek's Avatar
Drives: 2015 RS camaro
Sad .. One of the best performing v6 platforms on the market and no major company is working on cams for these motors . We don't even truly know the potential of these 3.6 engines when pushed to the limit yet
Flotek is offline   Reply With Quote
Old 06-08-2016, 09:36 PM   #4
crc91
crc91's Avatar
Drives: '14 1LS
I found a company that does regrinds of the cams. (They really only work on ford v6 engines and have made good progress for the v6 mustangs) and they even talked of doing a stroker kit for us but as you guys know we would need new Pistons, rods, and everything else. So it would get pricey but would give us about .3 more liters of displacement. They said they could probably work the heads a bit and while the cam profile would be smaller. It would kinda make the valves bigger? At least that's my way of understanding it. And I know the cam didn't get bigger LLT to LFX but I think I read somewhere that part of the hp gain comes from bigger valves.
Old 06-09-2016, 04:13 AM   #5
Kenny Camaro
Drives: 2013 1LT RS Camaro
I believe the intake valves went from1.66 to 1.86 inches.
Kenny Camaro is offline   Reply With Quote
Old 06-09-2016, 08:20 AM   #6
Shawno72
Shawno72's Avatar
Drives: 2015 Black 2LT RS M6
I know they flow better
https://youtu.be/D2Gd2IzJaFM
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
Shawno72 is offline   Reply With Quote
Old 06-10-2016, 12:20 AM   #7
mender
Drives: Fiero
38.3 mm vs. 36.96 mm (1.51 vs 1.46)
mender is offline   Reply With Quote
Old 06-10-2016, 01:38 AM   #8
crc91
crc91's Avatar
Drives: '14 1LS
That video was pretty informative as far as getting a look inside the cylinder head design. I wonder if that would even really be worth porting?
Old 06-10-2016, 07:27 AM   #9
Shawno72
Shawno72's Avatar
I think I've read somewhere where GM has done about as good a job as you can from the factory but I may be wrong
Old 06-11-2016, 10:22 AM   #10
DGM
DGM's Avatar
Drives: 2013 Camaro 1LS - Ashen Gray
they are really starting to payoff now..
"WIDOW" Overkill Edition w/Mace Cams,80mm tb,Jacfab spacer/ported intake,Alky Control,ARH off road pipes,SOLO custom system,3.91 gears, MGW,Phantom grilles,ZL1 appearance pkge, 3dCarbon vents, Lingenfelter hood and spoiler, PLX boost/wideband modules/gauge,ZL1 fuel pump,LF3 hpfp,DSS aluminum driveshaft,JPSS sway bars, Z28 replica wheels and CxRacing coilovers..
DGM is offline   Reply With Quote
Old 06-11-2016, 11:52 AM   #11
crc91
crc91's Avatar
Drives: '14 1LS
What power level were you at before and after you added your cams?
Old 06-11-2016, 12:17 PM   #12
Shawno72
Shawno72's Avatar
Yeah Dennis is Will getting you the results you wanted?
Old 06-11-2016, 12:29 PM   #13
Awit92
Awit92's Avatar
Drives: 2015 camaro 2LS
I believe the gains showed themselves after he added forced induction. But don't take my word for it.
CAI Cold Air Intake, Vitesse Motorsports TC, Solo High Flow Cats, Muffler + resonator delete, Magnaflow Resonated X-pipe, Apex Air scoop, VMAX ported throttle body, Drake Shifter, Z28 spoiler + Zl1-addons Wickerbill, Eagle Eye U halo headlights. Items blacked out/tinted: Hood, wheels, emblems, brake lights.
Awit92 is offline   Reply With Quote
Old 06-11-2016, 12:30 PM   #14
crc91
crc91's Avatar
Drives: '14 1LS
Oh yeah that's right he went FI after cams. I was talking to will and it seems like with these cams the more air the better they respond especially since they only make power way at the top end.
