![]() Drives: 2013 ZL1 Join Date: Nov 2013
Differential cooling loop question
I am adding a Solo Mach X muffler and I need to reroute the rear differential cooling lines. It is my understanding the rear differential cooler is cooled by the transmission cooler. My car is a Manual, so what pump is circulating the tranny fluid to the heat exchanger in the rear end? When I break the line how do I replenish the lost tranny fluid? I can not find any instruction for this. I do not want to replace the lines and end up having an air bubble that air bounds the rear end cooler. Any help or advice would be appreciated on how to get the fluid replaced and the correct level back in the tranny and how to get the air out.
Drives: Camaro Justice Join Date: Jun 2007
There is a cooling pump in the tranny that powers the closed system.
![]() Drives: 2013 ZL1 M6 Join Date: Aug 2013
Just top off through the fill plug driver side of trans after you reroute the lines.
417, Callies Magnum Crank, Oliver Rods, JE Pistons, Lingenfelter Heads, Comp Cam, Magnuson Heartbeat, 28% Pulley, E-85, Squash Fuel System, Afco, Rotofab, BMR, Hotchkis, Corsa, Kooks, IDA1300's, Comp Cam, Springs, Push Rods, Trunions, Nitrous Outlet, RPM 6-point cage, garage built
