Old 06-08-2016, 10:02 PM   #1
pdiddy
Drives: 2011 2SS
10.3 at 136 Ecs car
Took the car to Topeka and went 10.3 at 136 with a 1.64 60'. I plan to get the 60' better and go faster. Car is making 720 thru th400
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 06-08-2016, 10:13 PM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Congrats! Thanks moving out for sure
ttshovel is offline   Reply With Quote
Old 06-08-2016, 10:23 PM   #3
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Impressive, drop that 60' a tad and youre bottom 10s knocking on a 9
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 06-08-2016, 10:26 PM   #4
pdiddy
Drives: 2011 2SS
For the non believers
Slip of course
Old 06-08-2016, 11:33 PM   #5
ttshovel
ttshovel's Avatar
30mph on the back half!!!
Old 06-09-2016, 09:24 AM   #6
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Nice, congratulations!
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 06-09-2016, 09:38 AM   #7
SingleT
Drives: 2015 2SS
any weight reduction
SingleT is offline   Reply With Quote
Old 06-09-2016, 11:45 AM   #8
agent5
Drives: 2013 Camaro SS (+RS) + Hurst+ DME
Very impressive times, congrats!
Can you share some of your suspension setup?
agent5 is offline   Reply With Quote
Old 06-09-2016, 12:25 PM   #9
pdiddy
Drives: 2011 2SS
15" Conversion 1" lowering BMR springs stock otherwise.. FULL Weight 2SS interior NO weight reduction.
Old 06-09-2016, 01:20 PM   #10
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
Nice! How much boost?
DarkCry956 is offline   Reply With Quote
Old 06-09-2016, 02:13 PM   #11
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
What converter are you using?
camarosspower is offline   Reply With Quote
Old 06-09-2016, 02:35 PM   #12
pdiddy
Drives: 2011 2SS
FTI tranny and custom spec converter. 14-15 pounds
Old 06-09-2016, 04:47 PM   #13
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Nice that getting it done.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 06-09-2016, 05:39 PM   #14
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Still jealous of your wheels setup lol should have borrowed them why you weren't looking.
Trob85 is offline   Reply With Quote
