Old 06-09-2016, 06:45 PM   #1
Soybeanrice
Soybeanrice's Avatar
Drives: 2014 2SS/RS
Recovered a BIG Oops!
While I was changing out the engine mounts for some BMR polyurathane ones, I had to take off my intake manifold so I could raise the engine higher and remove the old stock mounts...
I rushed to put the IM back on and decided that if I wasnt gonna use loctite, that I would just tighten a little harder than normal.
Well, I paid the price.
I got lucky with an easy out
The IM bolt is special order from a stealership and is 25 bucks! Can you believe that?!
Soybeanrice is offline   Reply With Quote
Old 06-09-2016, 06:50 PM   #2
Ledzepx
Ledzepx's Avatar
Drives: 2010 2SS Camaro 6sp.
Weeeeewh you are sooooo lucky. So what are you gonna do. Overtighten them or loctite?
Ledzepx is offline   Reply With Quote
Old 06-09-2016, 06:53 PM   #3
Soybeanrice
Drives: 2014 2SS/RS
Old 06-09-2016, 07:57 PM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Those bolts are only torqued to 104in/lbs and in sequence. Glad you got the broken one out.
pg 76 on a pdf viewer shows the sequence.
http://www.techafx.com/sites/techafx...structions.pdf
More to come.
Black_SS10 is offline   Reply With Quote
Old 06-10-2016, 10:45 AM   #5
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Yea, convert that to ftlbs, and you can see how easy it would be to snap that head right off!! Gotta always check those torque specs!!
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
bolt, broken, intake, ls3, manifold
