Old 06-10-2016, 04:43 PM   #1
jussi70
Drives: 2010 2SS/RS IOM and Corvette C4
LSA pulley change
I just bought new 2.50" supercharger pulley. Itīs 2-piece pulley from JRE.
I found and watch videos...
Is it only way to change pulley to remove supercharger snout?
Is it possible to heat pulley and do assemly without remove supercharger?
And... I add picture of my car. This is from Finland.
jussi70 is offline   Reply With Quote
Old 06-10-2016, 10:25 PM   #2
BUNNY15
BUNNY15's Avatar
Drives: 2010 Rally Yellow 2SS/RS 6M ~~ LSA
We used a 7-ton puller from a local auto parts store and it worked great to remove the stock pulley which I would think you could probably do without removing the snout but how are you going to install the new pulley? Does it not need to be pressed on? My S/C was off so it was easier to remove the pulley, but we used a 20-ton press to press on the new pulley.
---Tiffany, the car junkie
HALNSS
BUNNY15 is offline   Reply With Quote
Old 06-10-2016, 11:49 PM   #3
hammdo
'It's an experiment'
hammdo's Avatar
Yep, 20 ton press is needed to install the new pulley and you need to support the rear of the snout shaft to prevent it from moving -- hate to say it, but the snout has to come off in order to install it...
-Don
747 RWHP 794 RWTQ
