Old 06-11-2016, 09:39 PM   #1
DonnieDarko94
Drives: 2014 Z28
Track Day, how to Prep the Z28
Hi,
I just bought my Z28 about two weeks ago and live in Monterey CA so Laguna Seca is the home track. I had a ZR1 before I owned this car and I have seen the sheet that Chevy includes with the car for suggest before and after track day use. I am familiar with bedding the rotors and burnishing pads.
However, do I really have to change differential fluid after every track day if that car already has 9500 miles on it and is still under factory warranty???
Seems a little excessive, since its just an HPDE.....Please post! My ZR1 seemed to need less work after a track day :( I dont want to tear up my car just want to have some fun.
DonnieDarko94 is offline   Reply With Quote
Old 06-12-2016, 04:54 AM   #2
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
That's definitely excessive. I wouldn't go that crazy about changing diff fluid. Depends on how much time you actually get on the track.
DOT4 Brake fluid, and clutch fluid are key as well.
Old 06-12-2016, 06:42 AM   #3
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
Here's the prep sheet:
http://www.chevrolet.com/content/dam...PREP_Final.pdf
69L48Z27 is offline   Reply With Quote
Old 06-12-2016, 07:31 AM   #4
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Originally Posted by 69L48Z27 View Post
... there you go. I think this is what he's reading.
Old 06-12-2016, 08:27 AM   #5
Bone Stock
Bone Stock's Avatar
Drives: 2015 Z28 Red Hot #1179 (sold)
Speaking of the track, met some guys at Lime Rock Park yesterday...before the rains came...
‘19 GT350R Oxford White
'15 Z28 Red Hot #1179 (sold)
'14 ZL1 Summit White, Recaros, 6M (sold)
Bone Stock is offline   Reply With Quote
Old 06-12-2016, 09:15 AM   #6
Synner
Drives: cars
Change it to a high quality synthetic so that it can better handle the heat. It's got a cooler, you don't need to swap it that often unless you're doing a more endurance oriented session.
Old 06-13-2016, 10:24 AM   #7
DonnieDarko94
Drives: 2014 Z28
I was recommended redline 75-110w think thats too much?
Old 06-13-2016, 12:58 PM   #8
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
use the GM fluid for our cars...Rear Differential Fluid 75W-90 LimitedSlip:
GM Part No. 88900401. Amazon has it for $21 a quart. Our cars take a little over 1 quart so buy 2.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 06-13-2016, 05:33 PM   #9
serviceguy
Drives: 2014 Z/28 # 89, 69 Camaro, 2013 ZL1
After several track days, my car has less than 400 miles. I thought..really I need to change the rear axle fluid already ? . Glad I did ! at 350 miles and several track days the fluid was already discolored. I have not followed the break in period, I believe in drive it like you stole it philosophy. The rear axle fluid will be changed on regular intervals going forward.
serviceguy is offline   Reply With Quote
Old 06-13-2016, 07:17 PM   #10
JusticePete
Drives: Camaro Justice
You will run your Z/28 much harder, create much high loads, carry greater speeds into the corner, through mid corner and onto the exit. The Z/28 Torsen differential will put down power hard for you. Change the fluid ;-)
Old 06-13-2016, 11:37 PM   #11
DonnieDarko94
Drives: 2014 Z28
all good advice! will do! shouldn't be too difficult to DIY right? or will the computer have a field day with me if I change the fluid myself?
Old 06-14-2016, 05:31 AM   #12
Stephen12ZL1
Drives: '21 ZLE A10
It is very easy to change the differential fluid. There are two plugs on the drivers side of the differential. Remove the lower plug with a 3/8" socket extension and drain the fluid. There is a fill plug above the drain plug. Use a small piece of rubber hose on the bottle nipple or transfer pump to get the new fluid in the differential. Approximately 1.2 quarts and fill until the fluid weeps out of the fill hole.
Old 06-14-2016, 07:15 AM   #13
JusticePete
Old 06-14-2016, 10:00 AM   #14
derek1387
Drives: 2015 1LS Red V6
1. Buy Z28
2.Fill with fuel
3. Bomb to track
4.?????
5. Profit! (AKA, kick some tail)
6. Bomb home!
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
maintenance, track car, track day, track driving, z28
