ANTI-MATTER Hawaii band
Drives: 2010 Supercharged SS, manual,Kooks, Join Date: Jun 2016
Checking oil level maggie
Aloha gang,
Just picked up a 2010 SS with a maggie 2300. I need to go thru this car to make sure its ok. 29,000 miles. Is there a way to check the oil level in the supercharger? Thanks |
Too much is never enough!
I found this on LS1 Tech, I won't claim to know whether its accurate or not, but I figured I would do some research for ya.
"they have a fill plug, but no way to check the fluid level,, the tvs2300 is factory filled with 205ml of gm supercharger oil,, you can pull the fill plug and suck out about 150ml and put the same amount back in,, but no actual way to check if its full or low" The thread can be found here. http://ls1tech.com/forums/forced-ind...questions.html
