Trunk Ice Tank for a Turbo Car? Interchiller?
I'm looking for some guidance on trunk ice tanks, and interchillers.
I have a twin turbo car. High under hood temps, high IATs, high coolant temps. I am looking for suggestions on what to do to help with temps. Trunk ice tank. I'm guessing this is tied into the intercooler system? Anyone running this on a turbo car? gas station ice isn't from distilled water. Any adverse effects? How bad is the condensation in the trunk? Interchiller Anyone running these on a turbo car? I saw the Australian company on here that makes them. Are these crazy expensive? (I like the idea of this. Closed system, no maintenance.)
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
Ice tank would need air to water. Interchillers can help with iat for a run but that heat is just dumped into the Ac condenser so hat does help with under hood or other temps.
I would start with a fmic swap. If that doesn't solve it all the next options are much more expensive.
Nick
Corvette Z06 -1200ish rwhp |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Another question is do you want to cut holes in your firewall if you run air to water. It's a smart move and will help but the pros and cons if I were you I would consider switching over to e85 which helps and adding meth injection. I'm not sure if you're putting it in your camaro so unsure what your plans were.
You can mount an air to water up front. Would be a lot of custom work, and have to tuck it up in the bumper.
Doesn't solve the ECT or engine bay temps. Just helps with IATs, which should not be an issue. Summer is only starting. Only gets hotter from here.
Nick
#5 | ||
And don't remind me about the summer! I know that all to well. But my car is not a DD. It doesn't sit in traffic. Mostly just weekend cruising and an occasional road trip.
Taco's 2014 SS
#6 |
Too much is never enough!
Get the carbon fiber hood with vents in it, and run meth. Also can get a bigger radiator.
