Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > V8 Bolt-Ons & Tunes
Old 06-15-2016, 06:47 PM   #1
Juiced1
Drives: 2012 2SS CAMARO 45th
SQUASH PERFORMANCE DUAL FUEL PUMP SYSTEMS - BEST PRICE WITH JUICED!!!
This is the highest flowing fuel system available for the 2010+ Camaro for both gasoline and E85. This dual fuel pump hanger is built from CNC machined 6061 aluminum and is completely sealed using o-ring construction. Nothing but the best components are used throughout.
The unit is built to use the Camaro's bucket "shell" to minimize the effects of fuel slosh. They are furnished with this part already installed so you don't have any extra down time.
Includes your choice of -8 and -6 AN fittings. The ports are both machined for -8 o-ring type fittings.
Our plug and play return-style wiring harness has double 10ga wiring, circuit breakers with mounting bracket, socketed relays, and plugs into the stock vehicle harness in place of the stock fuel pump.
A Hobbs pressure switch with 15' pigtail and sealed connector is used to fire up the 2nd pump at 1-2 psi of boost.
Some additional features:
Heavy duty sealed connectors
Pumps wired individually so you can power one pump using a Hobbs switch
Anodized for corrosion protection
Stainless steel hardware
Viton o-rings
Starting at $829.95 shipped!!!
Juiced1 is offline   Reply With Quote
Old 06-22-2016, 10:48 AM   #2
Juiced1
Big time power needs big time fuel
Old 06-29-2016, 10:10 AM   #3
Juiced1
This bad boy can handle just about anything engine set up.
Old 07-08-2016, 11:01 AM   #4
Juiced1
If you are going big hit us up!
Old 07-11-2016, 06:55 PM   #5
ClarityCamaro
ClarityCamaro's Avatar
Drives: 2013 black zl1
What's the max Rwhp this pump can handle on e85?
ClarityCamaro is offline   Reply With Quote
Old 07-20-2016, 09:47 AM   #6
Juiced1
PM sent, they can run 1250rwhp on E85 all day
Old 07-20-2016, 10:04 PM   #7
Mpighills
Drives: SS Camaro
Can you PM me a price for -8 an feed and return with e85 flex fuel and rails.
Mpighills is offline   Reply With Quote
Old 07-29-2016, 10:10 AM   #8
Juiced1
PM sent. Big power needs big pumps!
Old 08-07-2016, 10:42 PM   #9
Juiced1
SQUASH YOU FUEL SYSTEM PROBLEMS.
Old 08-16-2016, 09:58 PM   #10
Juiced1
The answer to your fuel system questions.
Old 08-24-2016, 09:24 AM   #11
Juiced1
Top pump on the market
Old 09-03-2016, 11:19 AM   #12
Juiced1
Squash pumps are your answer for big power.
Old 09-15-2016, 09:48 AM   #13
Juiced1
Big power needs big fuel.
Old 09-27-2016, 09:31 AM   #14
Juiced1
When you want to play with the big boys you'll need some big fueling options
dual fuel pump, fuel pump, squash, squash performance
