Old 06-15-2016, 07:04 PM   #1
1LESSCamaro
Drives: 07 Sierra Denali, 15 1LE
Start-up tune
Where can I get a start-up tune to get me to my tuner? I'll be installing an AGP twin kit (S256 turbos) with AUS 85lb injectors and a Kenne Bell boost-a pump. It would need to be HP tuners.
1LESSCamaro is offline   Reply With Quote
Old 06-15-2016, 08:37 PM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
AGP has a startup tune
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 06-15-2016, 09:43 PM   #3
1LESSCamaro
I thought so. Didn't want to bug them till I knew for sure.
