Old 06-15-2016, 09:15 PM   #1
Yeager1990
Drives: 2012 2ss/rs L99
Stuck on agp install I think
I'm waiting on the fuel system and while I'm mounting the turbos I notice the fuel lines seem to run right above the Passenger turbo I think I may have to take it back off to install the fuel system
2012 2ss/rs L99
Agp twin turbo 51/61
full 3 inch stainless works retro chambered catback
Tuning by Greg Adams
Yeager1990 is offline   Reply With Quote
Old 06-16-2016, 01:05 PM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Give Kevin a call, he will square you away. Those guys are excellent at helping customers.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 06-16-2016, 07:55 PM   #3
Yeager1990
Yeah I will just ran into the problem well after they were closed trying to get as much done at night out of the heat as possible. You wouldn't happen to installed yours yourself did u
2012 2ss/rs L99
Old 06-16-2016, 07:58 PM   #4
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
My feed line is located on the outside of the frame rail,and my return line is located inside the frame rail. My stock original fuel line is still at the stock location cap at both ends for now.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 06-16-2016, 08:25 PM   #5
Yeager1990
Gotcha just wondering because the agp fuel systems uses the old feed for a return and a new 8an for the feed so I assume I can just leave the stock one and run the new one like you said
2012 2ss/rs L99
