Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 06-16-2016, 07:16 AM   #1
Lonewolf583
Apex Predator
Lonewolf583's Avatar
Drives: 2010 2SS/RS M6 Rally Yellow
Road Race/Autocross Alignment Setup Thread
Didn't want to "muddy the waters" in the alignment help thread - I figure it would just get lost there anyways. Putting this out there to help with others in their setup choices.
Discussion Thread/Feedback on Alignment w/Slicks:
Tire: 275/35-18 Toyo RR Square
Hot Pressure F/R: 40/38
Springs and Dampers: GMPP Z28
ARB: GMPP Z28
Bushes: GMPP Z28
Race Weight: 4000 (Driver 200)
Philosophy of Use: Autocross/HPDE, Limited Street
Other Noteworthy Chassis: Stock Rear Subframe Bushes, No Strut Tower Brace, No Cage
Camber F/R: -1.5, -1
Toe F/R: 3/16" OUT, 1/16" IN
Caster: 6 deg est.
Car is neutral, "tossable". Eager to rotate at low speed. Car has a slight amount of push in high speed sweepers (my preference). Only noteable issue is slaloms. Car grips and loads up adequately (in my mind), but getting the car turned the other way takes some more effort; the ratio on the rack for these cars is slower than I'd like.
Need to get rid of the compliance in the rear and add more camber/caster for the RR's. Toyo setup sheet says -2.5 to 5 degrees of camber. I'll probably shoot for 2.5/1.4 camber next time out.
Feel free to share!
2010 Camaro 2SS/RS - LS3/TR6060, Paid Off \o/
Beating physics into submission since 1991.
Lonewolf583 is offline   Reply With Quote
Old 06-16-2016, 08:21 AM   #2
JusticePete
Drives: Camaro Justice
You are planning to run more negative camber than front camber?
Old 06-16-2016, 09:23 AM   #3
Lonewolf583
Apex Predator
Sorry Pete, not following. I'm planning to add more negative camber on both ends of the car and some caster. Shooting for a setting of -2.5 Front, -1.4 Rear Camber as a starting point.
Given the recommendation from Toyo, will eventually ratchet it up further while keeping an eye on my tire temps. Not sure how well the Z28 kit is going to jive with the aggressive alignment.
Could be doing some of this soon depending on when the SAI plates/caster locks come in I've already got larger eccentrics for the rear.
Old 06-16-2016, 10:03 AM   #4
JusticePete
Use half of the front camber in the rear as your split. You can add more toe out up front.
You may want to play with the bars. Smaller up front or bigger rear.
Old 06-16-2016, 10:48 AM   #5
Lonewolf583
Apex Predator
Thanks for the feedback. I'll start there.
Old 06-16-2016, 10:53 AM   #6
JusticePete
Works pretty well for us ;-)
Old 06-25-2016, 03:02 PM   #7
Cornercarver
Drives: 2011 2SS/RS M6
I've been running: (street tires though)
-2° front camber
-1° rear camber
6.5° caster is all I can get with caster adjusters
0 toe front and 1/16 toe in on rear
335 Rival S's on 18x12's
It works very well with my current setup. But front end push is always the most noticeable issue I have at higher speed stuff. Looking at getting some camber plates and moving to around 3° in the front and 1.5° rear.
Cornercarver is offline   Reply With Quote
Old 06-25-2016, 03:04 PM   #8
JusticePete
Originally Posted by Cornercarver View Post
I've been running:
-2° front camber
-1° rear camber
Which caster adjusters?
What are the sway bar diameters?
Do you mind telling us the weight wet ready to run?
Old 06-25-2016, 03:11 PM   #9
Cornercarver
Bars are whiteline 27mm fe3 style rear. Both are 3 way adjustable. Front middle setting rear is on soft
Caster bolts installed where GM didn't install them but the gates were there, I think they were rear toe bolts if I remember right.
Race weight is 3795 with 1/4 tank
Old 06-25-2016, 03:12 PM   #10
JusticePete
Wheels and tires please?
Old 06-25-2016, 03:13 PM   #11
Cornercarver
18x12 Forgestar F14 with 335 Rival S all four
Old 06-25-2016, 03:15 PM   #12
JusticePete
One more question please.
OE springs and struts, if coilovers brand and spring rates?
Old 06-25-2016, 03:16 PM   #13
Cornercarver
1LE dampers
Hotchkis 1" lowering springs. Rates are 220 and 550 iirc I'd have to verify that again
Old 06-25-2016, 03:18 PM   #14
Cornercarver
210 440 I was wrong
alignment, autocross, slicks, z28
