Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Transmission / Driveline
Old 06-17-2016, 01:57 PM   #1
Juiced1
Drives: 2012 2SS CAMARO 45th
GFORCE COMPLETE 9" REAR END KITS - BEST PRICE WITH FREE SHIPPING AT JUICED!!!!
Gforce Engineering is proud to introduce the bolt in 9" fabricated IRS rear.
The Gforce Engineering bolt in 9" IRS kit replaces everything from the transmission back with our heavy duty components.
Our bolt in 9" IRS eliminates all the flex, noise and clunking (and weak parts) found with the OEM rear plus you get a piece of mind knowing that your riding with the strongest rear you can get for your ride.
Our 9" IRS is rated for 1000+hp
Our 9" IRS is fully fabricated in house on our state of the art cnc fabrication equipment.
Our 9" kits come without the pumpkin, we can supply your pumpkin from Strange or Moser if needed.
We recommend going with the Strange Pro Iron pumpkin with the 31 spline Eaton Truetrac or the Moser case and truetrac.
You can add a pumpkin below in the options.
The 9" kit comes complete with:
* - Fabricated bolt in 9" housing that bolts up to the factory location
* - Heavy duty front mount with BMR bushing
* - 300m billet inner axle stubs
* - 300m Anti Wheel-hop axles with our heavy duty cv joints
* - 4340 billet outer axle stubs
* - 1 piece 3.5" Aluminum driveshaft (Carbon fiber also available)
STARTING AT $4899.99 SHIPPED
Juiced1 is offline   Reply With Quote
Old 06-26-2016, 01:13 PM   #2
Juiced1
Beefy stuff
Old 07-13-2016, 10:35 AM   #3
Juiced1
Huge power will always pop the rear at the track.
Old 08-03-2016, 08:57 AM   #4
Juiced1
Big time power requires a big time rear end.
Old 08-23-2016, 07:48 AM   #5
Juiced1
If you want to own the track
Old 09-08-2016, 08:26 AM   #6
Juiced1
If you want to own the track your path should take you here!
Old 10-01-2016, 10:08 AM   #7
Juiced1
1320
Old 10-16-2016, 10:49 AM   #8
Juiced1
9" rear end set up for huge power.
Old 11-03-2016, 09:05 AM   #9
Juiced1
For those who make sick power
Old 11-18-2016, 08:41 AM   #10
Juiced1
This rear end can take a pounding
Old 12-12-2016, 07:41 AM   #11
Juiced1
If you want to hit the drag strip with real power you'll need a serious drivetrain
Old 12-26-2016, 09:30 AM   #12
Juiced1
One nice rear end
Old 01-16-2017, 08:44 AM   #13
Juiced1
Solid rear end
Old 01-30-2017, 10:25 AM   #14
rdlawrence912
Drives: 2011 2SS/RS
"This rear end can take a pounding" ������
Gold...
rdlawrence912 is offline   Reply With Quote
9" rear end, axles, g-force
