![]() Drives: Black 2018 Camaro ZL1 auto Join Date: Nov 2012
Mechanical or spring tensioner?
Hi all. Need some info from anyone that has gone this route. I have a slp supercharger, cam etc (see sig) and have belt slip. I am trying to decide if I should go with a JRE/ADM style or MTI racing tensioner. Any advice/experience is appreciated.
2018 ZL1 A10 with PTB, ROTOFAB, Pulley and tune from
Vengeance. 607 rwhp/647 rwtq |
One Slow Automatic
Drives: 2017 GS 2010 CAMARO SS Join Date: Mar 2010
I have a JRE but the Adm one has an additional pulley for more belt wrap on the crank pulley...
650HP 2010 CAMARO SS 710HP 2017 GRAND SPORT
![]() ![]() ![]() ![]() Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
A mechanical tensioner will require quite a bit more static tension on the belt to account for belt stretch under load, which will be much worse for your alt/PS/WP bearings than the increased tension from an upgraded spring tensioner. If you also have a long belt, especially a 6 rib, that may still not be enough static tension.
![]() ![]() ![]() Drives: it changes Join Date: Nov 2010
Good strong spring tensioner every time for the reasons above.
With mechanical, you need to overtighten the crap out of things just to account for the fact you have a mechanical tensioner that can never compensate once the belt starts to stretch further. |
![]() Drives: 1968 camaro Join Date: Aug 2013
who makes the best heavy duty spring tensioner??
