Old 06-22-2016, 11:48 AM   #1
TheBandit18
TheBandit18's Avatar
Drives: 2011 Camaro 2ss M6
AC is Cold on passenger side and hot on driver side
Has anyone else have this problem? Tried reseting it didn't fix it and the actuator spins when changing Temps. I have a 2010 camaro ss
Thanks
TheBandit18 is offline   Reply With Quote
Old 06-22-2016, 11:55 AM   #2
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Do some 5th gens have dual controls? Meaning the passenger side can be controlled separately from the driver's?
If yes, then it could be some electrical problem, otherwise if one side isn't getting cold you could just be low on refrigerant, which means you have a leak
TommyTheCat is offline   Reply With Quote
Old 06-22-2016, 12:05 PM   #3
TheBandit18
I wouldn't think it has dual air controls the build date is September of 2009 so it's one of the very first ones
Old 06-22-2016, 12:45 PM   #4
Night trained
Night trained's Avatar
Drives: 2015 camaro 2ss 1LE
It is caused by a Low A/C charge...
Night trained is offline   Reply With Quote
Old 06-22-2016, 09:48 PM   #5
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
My 2010 was built in the last week of production and does not have dual controls.
When did dual controls start in Gen 5? (if ever)
Rock-It Man is offline   Reply With Quote
Old 01-24-2018, 02:14 AM   #6
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
i hope ur right. over the summer last year, i started noticing that it would take longer and longer for my ac to get the cabin cooled down now im getting the same symptoms as the op
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 01-24-2018, 10:28 AM   #7
Matt8892(2)
Drives: Black camaro 2ss 45th
They didn’t
Matt8892(2) is offline   Reply With Quote
