![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
Convertible Exhaust (L99) - What to do W/ Resinator
Ok to cut to the chase, I have LT Headers and Flowmaster Axleback. I also have the butterfly valves welded open.
What is entailed in getting rid of the resonator(s). I bought a magnaflow X-Pipe but it seems like there is some good modifications needed to make it work. The photo is the convertible exhaust I found online (not mine). I would like to eliminate the resonator in the middle. What would you do or have you done? Thanks!
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
I just bought an M6 exhaust and swapping my axle back to that. Just like in your pic.
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, Circle D, 3.91, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Here is my system, 3" all the back including x-pipe.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/Gesi cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
Thanks is that custom? Did you have a shop do it?
Ryan
Ryan
Complete exhaust is made by Stainless Works ( see their site) and installed by RDP with a dynotune.
#6 |
![]() Drives: 2011 camaro ss convertible Join Date: Oct 2015
I took my resonator off and istalled an magnaflow true x pipe in its place, just added more pipe to fill the gap
#7 |
How does it sound when the AFM kicks in?
#8 |
Not sure if its me who you're asking but mines sound real raspy when the afm kicks in, its not unbearable but it is really noticable. You get used to it it's not that bad, I can still have a normal conversation inside the car with no problem at all
#9 |
I have AFM removed (tuned off) Ryan
Ryan
#10 |
Abelardoo_12 & Ryanbabz71, thank you both for your replies. Yeah my message was for whoever wanted to chime in.
I have a Borla axle back & have been on the fence on deleting the Big O resonanator because of the different threads I've read about on the AFM. So that's why I asked about how it sounded. Thanks for your replies! |
#11 |
Thoughts about adding NPP exhaust? Can I just bolt on (minus a new rear diffuser)
Ryan
Ryan
#12 |
Ryan I have a set NPP Muflers if your interested and there's a guy in the exterior classifieds that was a 1LE diffuser for 80 bucks I think....
Orange Krush II
#13 |
![]() Drives: 2014 Camaro 2SS Join Date: Sep 2016
#14 | |
![]() Drives: 2011 2SS/RS Convertible Join Date: Jan 2017
https://www.summitracing.com/parts/s...t/model/camaro
Richard Partlow
