Old 06-23-2016, 06:23 AM   #1
Rcheli4fun
Drives: 2011 camaro 2SS RS
Headed out for first time to drag track ???
I have a 11 camaro with LS3 M6 Dyno at 482HP 444TQ and have the Nitto 275-40-20 555G2 Tires my question is what air pressure should i start at and how low is still safe pressure to run
any other advice would be great
Thanks
Rcheli4fun is offline   Reply With Quote
Old 06-23-2016, 07:21 AM   #2
JusticePete
Drives: Camaro Justice
22 and go down from there until you are happy with the grip.
If you have time, get to an alignment shop. Have them dial out as much negative rear camber as possible. 0.00 is great. Toe IN 0.12 per side.
Street tires or skinnies up front?
Old 06-23-2016, 01:02 PM   #3
Rcheli4fun
They are 275-40-20s nitto 555G2 all the way around
Old 06-23-2016, 06:18 PM   #4
Rcheli4fun
I do have a good pair of 245/45/20 Perrelli's I could put on the front but I didn't know about mixing tread and brand of tires It would save at least 12 lbs
Old 06-23-2016, 07:43 PM   #5
jrhagen
Banned
Drives: Camaro
Advice, just have fun. There are so many aspects to a great run with a M6. RT, wheel spin or hoop, 60', shifting. I would say start with launch rpm and 60', eventually, it will come together. Then you will want new wheels and tires and suspension upgrades.
jrhagen is offline   Reply With Quote
Old 06-23-2016, 11:00 PM   #6
2010SSRSM6
2010SSRSM6's Avatar
Thanks
Pete, these are the street tires, not drag radials. I don't think 22 would be a good starting point on these.
Where the 555G2's are a newer compound, I'd start at your normal running pressure and see what happens. If you do lower the tire pressure take chalk with you and put it across the tread pattern, if you do your burnout and don't take all the chalk off the tires, you let too much air out and your tires are cupping.
Old 06-28-2016, 10:05 PM   #7
Rcheli4fun
thought it would be faster seems like my 60' is high i was running 30 psi in rears unpreped track couldn't seem to get it to hook maybe just practice launching tried traction control on and off and launch control on and off anyone have any ideas
forgot in earlier post i have 3.91 rear gears
r/t .464
60' 2.263
330 5.856
1/8 8.72
Mph 87.86
1000 11.13
1/4 13.155
Mph 111.63
Old 06-28-2016, 10:51 PM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Hard to hook 482 rwhp, 3.91 gear, on street tires.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 06-29-2016, 06:08 AM   #9
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Mph is low. At the same power and gears I was trapping 115- 117. Maybe you need to shift at higher rpm like 7k. Shift fast don't let it nose dive
camarosspower is offline   Reply With Quote
Old 06-29-2016, 10:21 AM   #10
Pro Stock John
Writer
Local guy to me on 20" DRs went 11.9@122 with similar parts and rwhp.
PROJECT HEAVY CHEVY
Old 06-29-2016, 12:15 PM   #11
Rcheli4fun
I did watch video of my run and the front end did dive a bit before i shifted at 6200 rpm
Any suggestions for tire wheel combo ?
want to keep my brembo brakes
Old 06-29-2016, 06:43 PM   #12
jrhagen
Banned
Drives: Camaro
John, attach your wheel tire combo thread here.
Old 06-29-2016, 10:20 PM   #13
Pro Stock John
Writer
http://www.camaro5.com/forums/showthread.php?t=392950
PROJECT HEAVY CHEVY
